NewDriverOlderRide Posted May 31, 2006 Share Posted May 31, 2006 Would anyone of you be able to send me a couple links to the right seals/gaskets etc. that is required to do it? I've been looking on www.thepartsbin.com and I think I have found the "mouse" gasket, but when I look for the oil pump seals, theres like 3 different o-rings? do I need them all? or what? Gasket-- http://oem.thepartsbin.com/parts/thepartsbin/wizard.jsp?year=1993&make=SU&model=LOY-4WD-001&category=A&part=Oil%20Pump%20Gasket&dp=false Seals??-- http://oem.thepartsbin.com/parts/thepartsbin/wizard.jsp?year=1993&make=SU&model=LOY-4WD-001&category=A&part=Oil%20Pump%20Seal&dp=false Thanks Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 31, 2006 Share Posted May 31, 2006 yes you need the gasket, the "mouse" style. on the seals link you posted, there are three seals. you'll need the top two, not the bottom one. the top one is the oring that goes inside the pump housing. the second one is the seal on the outside of the oil pump, that the shaft goes through. the last one is for the oil pick up tube in the oil pan. you do not want to bother with this one. firstly getting the oil pan off is annoying....and that's the easy part! no need to replace this one. in all there are 3 parts needed for an oil pump reseal on an EA82. the o-ring, the mickey mouse gasket and the shaft seal. on the ER27 (XT6) it's the same except it does not have the oring inside the pump housing. Quote Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted May 31, 2006 Author Share Posted May 31, 2006 Thanks A Bunch! Quote Link to comment Share on other sites More sharing options...
