Switch rear drum brakes to disc? ['96 Legacy Brighton]
4 replies to this topic
#1 porcupine73
porcupine73
    Obligate carnivore
  • 5,214 posts
  • Buffalo, NY
Posted 21 August 2006 - 07:48 PM
Hello all, have a '96 Legacy Brighton here with front disc and rear drum brakes. Does anyone know if any other Legacy's of that year had disc brakes on the rear, and if yes, if I'd be able to switch over my Brighton's rear drum brakes to disc brakes. Would it be worth making this change; I only sometimes drive it like I stole it.
#2 the_bard
the_bard
    Upstate NY'er
  • 941 posts
  • Rexford, NY
Posted 21 August 2006 - 08:42 PM
Can't say anything about the '96 Legacies, but my '97 OBW has got rear discs. According to cars101.com, the '96 LS, GT, and LSi sedan/wagons all had the rear discs standard. The L's had 'em as optional. Good huntin'!
#3 dmanaenk
dmanaenk
    Eat, Live, Breath Subaru
  • 311 posts
  • AA
Posted 21 August 2006 - 09:02 PM
Any other legacy except brighton has disk brakes. I am thinking about it, just don't have much time now.
You'll need complete rear hubs with brake lines and e-brake cables.
#4 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 22 August 2006 - 12:52 AM
It is a fair amount of work and expense so it would depent how long you are going to keep the car. I considered this on my 99 Forester but decided to stay with a new set of drums and shoes instead. I assume you would need a proportionng valve to balance front and rear or perhaps a new master cyl if it's built in.
I know it has been done a number of times and info should be available. I figured if I had gotten 100,000 miles out of the stock rears that an easy to comeby set of drums (about $20 apiece if I recall) and and a couple sets of inexpensive shoes would probalby go as long as the engine.
A bit less than 30,000 miles later this seems to be working out OK.
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,214 posts
  • Buffalo, NY
Posted 23 August 2006 - 06:21 PM
Thanks for the info. Sounds like a lot of time&expense. Well I think I'll just stick with the drum brakes; they seem to work OK. Unless I can get all the parts I need from a salvage yard and just rebuild the calipers! schweet...:headbang:
