how to install oil and volt gauge
2 replies to this topic
#1 sickofitall1113
    New User
  • PipPip
  • 12 posts
  • MA
Posted 09 November 2003 - 10:39 PM
does anyone know how to install an oil gauge and a volt gauge? like when to put the sensors and all that, if you do know please respond and let me know, thanks so much, gerry
#2 NOMAD327
    Eat, Live, Breath Subaru
  • 343 posts
  • danville, PA
Posted 10 November 2003 - 07:20 AM
The oil gauge sensor would normally be installed where the existing sensor is installed using a pipe tee. A volt sensor can tap into the electrical system anywhere almost, One wire to a positive lead that turns off with the switch off, and the other wire to ground.
#3 frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 10 November 2003 - 09:31 AM
One advice and one info.
1) use a flexible line not a copper one like I did. Someone here use a braided teflon line and I cannot find same here. Would very much like to know where I could order one online...
2) For the volt meter I used a Radiodhack rectangular meter (about 12$ US) that I mounted inside an audio cassette plastic individual case and that I plug in the cigarette lighter receptable. The recess under the stereo holds it in a stable position. It's maybe not as tidy as a dash mounted meter but it's cheap, easy to install, and you can carry it with you to another car.
