different a/c compressor?
9 replies to this topic
#1 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 14 May 2007 - 06:23 PM
1989 EA82 2wd sedan 5spd. EA82 motor from a 4wd which also had a/c.
I just got my a/c compressor bolted on as well as my power steering, but not the alt yet. i just noticed that the a/c compressor sits back about 1/4 of an inch further than the power steering or the main crank pulley.
It just doesn't fit correctly.
What's my problem here? did they make 2 different a/c compressor brackets for the EA82?
I also did a reaseal on the same engine and forgot about one small o-ring... well 2 actually, and it's more of a hard plastic than rubber and it's flat. It sits between the cam tower and the head towards a lower corner on each head, and it's only about as big around as a dime if even that. I blew each one out with an air compressor and broke them both, figured if i just sealed around it with anaerobic sealant that it would do just fine cuz it didn't even look like an actual gasket when it blew out.
Should I worry or will the anaerobic sealant hold well enough?
Thanks 5 million.
-Jordan
#2 misledxcracker
misledxcracker
    Guy no one ever answers
  • 846 posts
  • Bullhead City
Posted 14 May 2007 - 06:42 PM
No idea on the AC as I dont even use mine...
But, I'd replace the O-rings, dont put sealant up in there...
#3 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 14 May 2007 - 06:52 PM
yeah, i tried not to get any sealant IN the hole. is there anybody who has done the same thing I did and accidentally destroyed the o-rings?
#4 misledxcracker
misledxcracker
  • 846 posts
  • Bullhead City
Posted 14 May 2007 - 06:56 PM
if i know what you're talking about correctly... is it the cam case o-rings?
those are readily bought if so... i'll find a link
#5 Gloyale
Gloyale
    It's a sickness
  • 10,845 posts
  • Corvallis, OR PNW
Posted 14 May 2007 - 10:43 PM
If any of that comes loose it will surely end up clogging the cam bearings entirely. You would have no oil to them and who knows how quick they would seize. I would pull those cases off and put O-rings in there. This o-ring going bad can cause leakage an TOD as well so seal t right. I'd pull apart the oil relfief valve for the cam cases too and clean out the passages. Did you buy the correct A/c compressor for youre car? there are 3 types over the years.(only 2 in any model year though)
#6 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 15 May 2007 - 03:12 AM
i left the a/c compressor on the car when i pulled the engine. the bracket it sits on is the same and everything. just the block and heads are
#7 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Wtf?
#8 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
#9 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 15 May 2007 - 03:28 AM
You DEFINITELY need to replace those cam case O rings. Preferabbly with an OEM part, available cheaply from www.thepartsbin.com
#10 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 15 May 2007 - 11:28 AM
yep, ordered those seals. i might just take the a/c compressor off cuz I never used the a/c because it wasn't charged anyhow.
