kthiemann Posted September 26, 2008 Share Posted September 26, 2008 G'mornin, Am getting ready to put a new t-belt on my 00 forester and was wondering if there is anything special I need to know? The only other scooby t-belt I have replaced is my 94 impreza and they look like they are the same but...... Thanks. Quote Link to comment Share on other sites More sharing options...
Bmm001 Posted September 26, 2008 Share Posted September 26, 2008 (edited) http://endwrench.com/images/pdfs/StepEWAug07.pdf http://endwrench.com/images/pdfs/TBeltEWWin05.pdf http://www.ultimatesubaru.org/forum/showpost.php?p=19460&postcount=37 The end wrench articles are detailed and have good diagrams/images. Brian Edited September 26, 2008 by Bmm001 Quote Link to comment Share on other sites More sharing options...
rlsimpso Posted September 26, 2008 Share Posted September 26, 2008 I recently did a cam belt on my 98 Legacy GT. Here are a few things I noted. Take the radiator out. This makes a lot more room. Loosen the bolt on the AC pulley before turning the adjuster bolt. Mine was plastic and I broke it. If you aren't taking the crank bolt off with an impact wrench, have some one hold the brakes to keep the car from moving when you wrench on it. I had a 4 foot pipe on a breaker bar and was able to move the car easily. Supposedly there is a place to insert and pin to stop the engine from turning, but I didn't see it. If you have an auto, an impact wrench would be better. Clearing the condenser may be a problem. Get a good universal joint and it should work. It worked on my Mitsubishi van anyway . Be sure to check the cam belt tensioner. You may want to replace it and the water pump since you have everything apart. Watch the your don't get your hand under the cam belt on the sprockets. They have move suddenly if on the top of a lobe. It is an uncomfortable sensation. Be sure you tighten the crank bolt. They can come loose and crank pulley will wobble causing problems. Quote Link to comment Share on other sites More sharing options...
torxxx Posted September 26, 2008 Share Posted September 26, 2008 dont pull the radiator. take the cooling fans off, save yourself a few gallons of coolant. if its dual cam 2.5 before u take your old timing belt, take needle nose vicegrips to hold the pulleys in place since they are under spring pressure from the valve springs. If its a SOHC engine its almost identical to the 94 impreza belt you put on if its a DOHC you are going through the same motions, just with 2 more pulleys and a lil different marks. intake pulley marks point at 12 oclock, passenger exhaust pulley mark points at 9 oclock drivers side exhaust pulley mark points to 3 oclock. if u have them in the right spots, the double hash makes on each pulley will light up together as for taking the crank pulley off, of u have a strap wrench or a chain wrench u can hold the crank pulley with that Quote Link to comment Share on other sites More sharing options...
kthiemann Posted September 27, 2008 Author Share Posted September 27, 2008 Thank you for the comments/suggestions. Quote Link to comment Share on other sites More sharing options...
