Dirty idle control valve - Why
7 replies to this topic
#1 anaphe
anaphe
    New User
  • PipPip
  • 20 posts
  • calgary
Posted 13 January 2004 - 02:03 PM
So I had some stumbling at idle a few months back and cleanded the IAC valve with great success and then the car ran like a champ BUT it is now getting bad again after 3 months. Why is this happening?
Is it blow by causing this? Car has 190K KMs on it and seems to run great still with lots of power.
#2 ScoobySchmitty
ScoobySchmitty
    I am The Stig.
  • 475 posts
  • Kalamazoo
Posted 13 January 2004 - 02:07 PM
I've got the same problem. Your IAC might be going bad. I really need to replace mine, my cold idle is non-existant!
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 13 January 2004 - 02:10 PM
the pcv valve dumps a misty oil blow by back into the intake.....and I guess just normal operation causes them to get gunked up.
#4 anaphe
anaphe
    New User
  • PipPip
  • 20 posts
  • calgary
Posted 13 January 2004 - 04:01 PM
NT
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 13 January 2004 - 05:45 PM
ehh....it won't fix how the pcv system works. It's just that way... Only thing you can do is put a catch can from all the breather vents before they go back into the intake track. Other then that....keeping the oil from the breathers is a lost cause.
#6 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 13 January 2004 - 07:06 PM
and with that many Ks it deserves a bit of wear. A lot of other engines would already be dead.
I would just plan on doing a cleaning every few months as long as you plan to keep the car.
#7 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 14 January 2004 - 02:04 AM
Erm, Josh...the Subaru PCV works "backwards" compared to most others. The PCV valve draws straight from the crankcase, pulling fresh clean air - ahhh! - through from the valve covers. My point: A catch-can/oil-separator would only be needed on the hose that connects up to the PCV valve.
#8 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 14 January 2004 - 10:46 AM
I'll have to take a look at the pcv diagram.......I think I remember it acting different depending on how much vacuum you have or throttle position.
