Help! Rust ate my fuel filler neck.
5 replies to this topic
#1 marcia1723
marcia1723
    New User
  • Pip
  • 2 posts
  • New York
Posted 21 April 2009 - 08:10 AM
Now my check engine light is on, gas leaks out when I pump gas, and my engine runs like garbage. On the other hand, I love my little car (2000 outback sport), just had lots of body work done to repair accident damage, and don't want to get a new car.
Is there some way to fix this that doesn't entail taking off the quarter panel and spending lots of money?
p.s.
If you see this post elsewhere on this site please forgive me. I can't figure out how to post at will and am not sure the best location to post this anyway.
#2 Nutt_resuved
Nutt_resuved
    New User
  • Pip
  • 4 posts
Posted 23 April 2009 - 07:42 PM
You might wanna take the fuel tank out for cleaning and replace fuel pump filter and fuel filter as well since rust can clog there and make engine hesitated.
Alex
#3 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 28 April 2009 - 11:34 PM
You can replace the neck. It has a hose at one end to connect to the tank that is about 1.25" and then a few screws and hoses in the right rear to unbolt and move. Go order a new one at the dealer (probably not cheap but what ya going to do>?) and you will see how it works.
#4 XCR583
XCR583
    New User
  • PipPip
  • 18 posts
  • Slippery Rock
Posted 29 April 2009 - 06:17 PM
Just did this about 2 months ago on my Outback. Like Shawn said, pull right rear wheel. There is a plastic guard there, undo a couple bolts/screws and take guard off. Some of these maybe pretty rusty, I broke a couple off doing mine. Open up fuel door, there are 3 screws here to undo. I got 2 out, had to drill 1 out. Undo the connection to the rubber hose under the car and then pry the metal filler neck out. Will also have to undo rubber hose under plastic guard for the evap system. I did the cheap way of fixing the filler neck. Sanded it down really good and found several pin holes mainly where the plastic guard is, it collects dirt/water. Anyhow, sanded it down, covered holes with Quick Steel, its a puddy that you mix together, said it could be used for gas tank repairs, figured it would work for this. Was also told to use JB Weld. Covered all the holes with the Quick Steel really good. No gas leaks now. Sprayed filler neck with rubber under coating. Called Subaru and was told ~$130 for filler neck. Hope this helps!!
#5 greg donovan
greg donovan
    USMB Regular
  • PipPipPip
  • 60 posts
  • Fargo, ND
Posted 07 May 2009 - 08:36 PM
your post helped me. thanks a ton. funny how the obvious stuff like patching the pin holes gets missed. hopefully mine isnt too bad.
#6 kingbobdole
kingbobdole
    Mr. XT-6
  • 1,654 posts
  • Longmont
Posted 07 May 2009 - 10:22 PM
I just did this to an MI car like two weeks ago... We got a whole new pipe from the dealer. Covering rust holes=future rust. Like mentioned, it's a real cake job... but have the PB BLaster ready:lol:
