Everything posted by iayers
what next? did plugs/wires/coil... misfires + shaky engine
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD, how rapidly can these thing degrade? Is there the possibility of rapid failure? Before I can fix this, I am planning on doing 500mi of holiday highway driving. Can anything be added to the oil or fuel to protect it? How do I know it's BAD??
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, runs same cold as hot. Guess it's time for a compression test.
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf one valve burns, can this cause other cylinders to misfire, or is it possible that multiple are burning out. The problem has gradually gotten worse over last months.
99 OBW 2.5, 200k I'm getting a very rough idle & rough engine performance at all RPM's. ALL cylinders are misfiring. The car shakes pretty good and CEL flashes at idle. Replaced plugs, wires, and igniter/coil (all OEM, NGK, as recommended). Did not improve whatsoever. The car has been throwing P0420. I ran the car with the O2 sensor unplugged then plugged. No difference in performance. Smells like fuel when running. Been running fuel injector cleaner regularly. Recently Seafoamed the engine through brake booster. There are no exhaust leaks. What should I do next in the line of fixes? Given what I did, what does this sound like? Timing belt? Valves? Cat? Fuel? What would a good Subaru mechanic know to do on this? I will probably need to take it to a guy to check timing, compression, etc. Any help appreciated. Thanks guys. Or, direct to another relevant post?
P1443 Evaporative emission control system vent control function problem???
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuys, thanks for the replies. I ran a can of seafoam through my gas tank, drove the tank empty, then cleared the CEL codes. I've driven 300 miles since the codes were cleared, with no CEL. The guy at Autozone who cleared my code said that an open gas cap can cause P1443. Obviously, I have read the plethora of posts about the gas cap setting off the CEL, but I don't rememebr reading that it caused a P1443 code. The Autozone guy suggested that it did. I doubt that I failed to secure the cap at any point, but whatever. Anyway, maybe the can of seafoam cleared out some thing in the fuel system that was throwing that code. One thing's for sure... the engine feels a lot smoother and I don't smell as much "gas smell" in the exhaust when I first start up the car. All good things. I guess the moral of the story is... seafoam the crap outta yo rig... before you do anything else.
I pulled P1443 out of my 99 OBW man. Also pulled misfire codes out for 3 cylinders. I've pulled misfire codes before, but I never actually feel the misfires when the CEL is flashing. What is the deal with the evaporative emission control system? What is that? Does it suggest an exact part(s) that should be replaced? Is it a cause of misfires, or is it affected by the misfires? My car has new OEM plugs, new OEM wires, I've cleaned the fuel system and the throttle body with seafoam. Any info is appreciated. I'm open to checking stuff with my ohmmeter. Thanks, Ian
oil burning?
iayers replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust another thought. You said no obvious oil leaks, but I would make sure to do a thorough check. For example, if you have a bad rear main seal, or some other hard-to-see gasket, she might not notice it, especially if the leak doesn't drip straight onto the ground. My oil separator plate was leaking badly for a while, and it leaked a 2-3 quarts between oil changes- and it leaked onto a hot exhaust pipe and didn't hit the ground. Otherwise, I hope the engine dies close to home, or at least near a good bar.
need some ammo for my mechanic
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow, so, with all of your help, I resolved the problem, and saved myself a bunch of money. It turns out that the mechanic must have not unplugged the front O2 sensor when he dropped the exhaust out. Richierich hit it on the head. While the mechanic re-plugged in the sensor's wiring harness after doing the job, he didn't realize that he damaged the harness. One of the wires had pulled out of the wiring harness, creating the open heater circuit fault. I just jammed that mofo back in. A simple fix, but all of your posts really made it easy. The mechanic apologized when I told him that I fixed it myself... he offered me a free oil change... but that doesn't add up to the $200 he was certain I needed to pay to get my O2 sensor to work! I think this should have been an obvious fix for a mechanic who's worked with these cars before... Had Advance Auto Parts clear the CEL codes, and I got the car inspected yesterday. Anyway, thanks a lot everyone- I think I oughta donate some $ to this board.
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere is the front O2 sensor? Is it something that I could inspect the wiring if I could get under the car? Is it easy to access/replace the front O2 sensor myself if I bought one? Is there a notable difference in quality among the Subaru OEM model and other brands like Bosch, AC Delco, Walker... ? Thanks to RallyKeith
99 OBW MT, 130k. Just had a local reputable Subaru mechanic replace my clutch, replace a leaking oil seperator plate, cut off the vibrating heat shields, and do the rear main seal. He appears to have done these tasks successfully, but: When I picked up the car from the service, the mechanic said that my Check Engine Light was on, and that I need a new O2 sensor. The CEL was NOT lit before I dropped off the car, 100% for sure. I had Advance Auto pull the OBDII code: P0135, O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1). Here's what I've done based on reading previous posts... Monitored gas mileage for about 500 miles, it is 27 mpg, pretty good. I've unplugged the battery to reset the codes, but the CEL relights as soon as the car is turned on. At highway speeds, sometimes the CEL flashes for a short periods of <10 sec. For you all: What could the mechanic have screwed up? What can I do myself to check for errors? Is there a wiring harness or something I can check for continuity? Could cutting off the heat shields damage some nearby wiring or something? Do these sensors go bad at my mileage? Any insight greatly appreciated... the car is overdue for inspection so I gotta fix this asap.
what is gear play? what wears in a m. tranny?
hi everybody. so, obviously, transmissions wear out over time. my 990bw manual tranny doesn't feel like it did when it's new. (125k on it) but i don't understand what causes it to feel different. for example, lets say I'm in 3rd gear, and i'm driving down a flat road with my foot on the gas. if i quickly take my foot off the gas, the car will sorta lurch forward as it initially starts to slow down. if i were to step on and off the gas, say every other second, the car would be jumping backwards and forwards. when the car is new, if i were to do these same things, the car wouldn't lurch or feel as rough. i don't know if i'm describing this right.... in my mind, i mechanically visualize "play" in the gears, so when i'm stepping off the gas and the torque on the tranny reverses, the lurch i'm feeling is the transition from when the engine is pushing the transmission to when it is slowing the transmission. how do i get the transmission to feel "tight" like when it's new. does the clutch have anything to do with it? might the tranny mounts be loose? what have people typically experienced? thanks.
Transmission has delay in engaging
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's what I did, and it seems to have corrected the problem as I originally described it. Just did this about a month ago... 1) completely drained transmission fluid 2) replaced with brandy-new transmission fluid works like it did when new now. i figured that before go invasive to try this. glad i did.
Hi... dealing with an automatic transmission for a 1999 Outback SUS. SYMPTOMS: When put in gear, from park to drive, the transmisssion does not engage for some period. In this period, when I apply the gas: no go. It takes from 2-3 to 10 seconds for it to engage. This is also true for reverse. Like a long delay for it to engage into gear. However, no problem shifting to other gears once engaged. The problem is worse when car is cold or hasn't been driven. Aside from a good tranny fluid flushing and refill (which has been done already with no help), what do the USMB experts think might be the problem? Could this be electronics? What steps should I take before buying a new/rebuilt transmission?
2.5L Oil Seperator Plate leakin' - new question
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis $650 a good quote for the replacement of the oil separator plate and replacing the clutch in my 99obw, manual tranny? how much additional should requesting the rear main seal and replacing the flywheel each add to the quote, given that the tranny already needs to be dropped out in the above quote? i love this messageboard.
99obw - steering coupler rattle? over bumps
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXexcellent... about what range of prices will a mechanic charge to install the new dampened u-joint part? i saw the part listed on 1stsubaruparts.com for about $90. how invasive is the install? is there a guide someone wrote up somewhere? I noticed the part WAWalker listed is for the legacy model. i found an article that lists a specific part# for the outback: 34160AC090. or does the 34160AC030 part # do the trick for legacy outbacks as well as legacys? thanks
(i would have thought this issue was already discussed on the board, but couldn't find it... sorry if this is a repeat...) SO. I get a distinct rattle when I and turning tightly, and I drive at a SLOW speed over a sharp edge (say, a lip of a parking lot, or grate, etc....) I have a 99 outback wgn with 103k miles. I feel the rattle in the steering wheel (reverberates for a second after you hit the bump). And it can be heard, as a muffled low frequency rattle coming from the front of the car. I actually got to demo it to a Subaru mechanic, he noticed it. He said that it was the steering coupler (or something like that). And that it is common and has no detrimental effects. I'm fairly certain that this is not anything loose, it's not bearings, and it's not CV related. It only happens during tight turns, and I only notice it when going slow, as in under 20 mph. What is this? Was the mechanic right? Is this bad? Thanks. There are some really knowledgeable people on this board, it's awesome. Such a big help.
iayers replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks to you all for your responses. it was very helpful (and a bit comforting) to find out that recent work didn't require the removal of the (manual) tranny and engine. i think i will write a letter to subaru as suggested to see if any of the cost for repairing could be shared. and since it's not fatal to let the thing leak for a while, sounds like i have some time to spare. my mechanic mentioned that if the oil seperator plate is leaking, it might affect the clutch. is it possible that some small amount of oil makes its way to the clutch?? thanks y'all
how fast could/should we go?
is there anything wrong with doing 100 mph in a 99 2.5L engine? (other than its against the law) Will driving at, say, 90 mph for an hour or so really put A LOT of strain on the engine? (given that the engine has been well maintained?) how fast can i take my 99obw? for those have maxed that sucker out...
Hi. I'm aware of some of the existing posts on the seperator plate... (2.5L oil separator plate leak??? ) Here's the background leading to my questions: My 99 OBW's oil separator plate is leaking at 103k miles. The warranty JUSTended at 100k. It was a great warranty. At 98,000 miles, I had the VC (viscous coupler, the AWD transfer clutch mechanism) replaced under warranty. At 99,500 miles, the head gasket blew, and it was repaired under warranty. I don't know the exact details of what was done in the repairs. My local Subaru dealer (not the one that did the above repairs) diagnosed the oil separator leak, but said that recently done repairs could NOT have caused the leak. They said I will have to pay for the repair. (the original repair dealer is 5 states away now) I didn't like their answer. Now... both of the aforementioned repairs are under warranty, even though my warranty is up. MY QUESTIONS ARE: Was it likely that the oil seperator plate was replaced when Subaru dropped out the (manual) tranny to do the VC, or when Subaru repaired the head gasket? Is it standard operating procedure to replace the plate? Should there have been evidence of it leaking? Does the plate often leak? Could serious overheating (from my gasket going) cause the seal to degrade? Basically, I'm looking for ammo to make the claim to Subaru that they were neglectful of completely repairing the car when they did the VC work and head gasket work under the warranty period. I'm in college... I don't have money, and I don't have the time to drop out the tranny, so I gotta sqeeze this out of Subaru. It's just crazy to me that Subaru was RIGHT in there to replace/check the plate twice and didn't. I bet they saw the thing leakin, but left it so that I'd come back and have to pay for it. I'm pissed. Any help you can give is invaluable. Thanks.
