naz
Everything posted by naz
  1. not sure if this is the right forum on this board.. i need an IAC for my 1991 loyale, 5spd, EA82, SPFI my local dealer wants an insane $300, and i'm not having any luck with the junkyards so far. if anyone can help out i'd reall appreciate it thanks. my email ngn2@cornell.edu
  2. thanks for the links (i'm such a n00b)
  3. Hi guys, i was wondering if anyone could offer insight into my problem. the car is a 1991 loyale 5spd with the SPFI EA82 motor when i first start the car, especially when its cold, i need to blip the throttle for the engine to start. then the idle is very low, like 500rpm. the idle used to go up to 2000rpm and stay there for a while and slowly go down. the check engine light goes on and stays on too. also, when i step on the clutch, and the rpms drop back to idle, sometimes if the motor was turning at like 2000rpm then the idle will drop so low the engine stalls. this usually happens when the engine is still cold. when the engine is warmed up, the rpms still drop pretty low (so low all the dash lights briefly come on.. but the rpms rise to a normal idle) the car drives ok though, and i dont notice any problems other than at idle. when it first started to get cold, the CEL would come on, and then i'd drive around for a bit, turn the car off, and then i'd turn the car back on and the car would drive normal it got worse recently and i changed the O2 sensor, but it didn't make a difference. when none of the ECU connectors are connected, key on engine off, the ECU light just gives me 5 quick blinks then pause then repeat. i thought that in U mode i'd get an code that triggered the CEL... so ya.. sorry for the long post.. i don't have much subaru experience and the chilton's isn't giving me any ideas thanks
  4. my front wipers stopped working recently. i picked up a used motor from a junkyard. when i plug the electrical connector from the chassis wiring harness to the 'new' motor, and hit the wiper switch to low or high, there is no movement. does the wiper motor need to be bolted in to be grounded? and second question is that there never seems to any current going to the prong in the connector going to the wiper motor that the green/blue striped wire goes into (there is one prong that always has current, one that has current on high only, one that has current on low only). is it normal for one of the prongs not to have any current ever? if one of you guys with a loyale with a working wiper could verify it would be so awesome thanks a lot guys
