Everything posted by centrino
buttons and lights
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, don´t see your answers... when i can i will put some photo of the interior, yes, don´t have the cup holder in spain in this models... i need one...
Timing belt autocheck?
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for all!!, i´ll try to find this indication, but i´m afraid that in Spain, not have this professional dealers...
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks very much, in a volvo 850 that i have when i change the timing belt, the one used was in very bad conditions, cracks, hard rubber, i think the visual check is not the most secure, but maybe help me.... thanks again.
There is some way to chack that the timing belt is in good condition? i buy recently a legacy of 1997 2.2, and have 107.000 km. and i don´t know if timing belt is the original or new. in the dealer, don´t know, and i need to know if Timing belt is in good condition, because the change is very expensive (500$) Thanks.
96 legacy oil leaks
centrino replied to subbydoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do you Know exactly what is the problem? my 1997 legacy, have a very little oil leaks, but the engine don´t have a leaks, and steering pump don´t too. transmision maybe the problem. timing belt-oil.... i don´t understand the relation.. What is cam seals and crank seals? oil pump is defective in this years of legacy? Sorry for my ignorance... :-\
Lid assy Manual trans, LOCK
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, taking advantage of the occasion, i want the 29) Cup holder and 30) Cup holder Case too Price? Thanks.
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, Burgos is in Spain. I need the little piece nº 5. I don´t know how much....
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs for a 1996-1997 SUBARU Legacy SW. thanks.
I need the number 5 in this illustration: Someone knows a cheap solution for this problem? i don´t want to buy a New lid assy....
Cargo cover of old model, fits in my car?
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes thats right, the long of a 1990 is 135 cm. and in 1995 is 140-145 cm... thanks for all...
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone can tell me what size is the cargo cover of the first photo, model year 1991-1995. If someone have one.... thanks for all. I look in a cars graveyard....:-\ regards.
This cargo cover: Fits in this car? Thanks.
AWD or FWD+AWD
I Know that the forester have the traction in 4 weels, and is permanent, 50% in front and 50% in rear AL THE TIME. But in the owners manual of legacy, i read that the AWD isn´t permanent, normally is FWD, and when is neccesary it converts to AWD. I think all subarus have the AWD permanet, and this is the reason for the good results, compare with volvo cross country and similar. (the Outback is better than volvo in hard conditions...) And outback? is like forester or like normal legacy?
buttons and lights
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks!!!
buttons and lights
Did you know if the "buttons-symbols" that are marken in green have light at night?
Hi! battery disconect and cel light
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToday i do a long travel, and the cel don´t light, i think the reset was the solution. Thanks all.
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks very much, why is important run the engine (with the car stopped) for 15 minutes? when i connect this morning i drive 10 minutes to work and all OK. Thanks again!
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry i forget to answer.... What is "canister purge valve" in Spanish.. or where is located?, or what is his function? and where is the obdII conector in my car? under the steering weel?
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, connecting the ecu, the problem is "temperature of motor" and "slow motion" that says the mechanic, the mechanic says that it did not remember the code numbers... The mechanic says that it is not connector OBDII in my 1997 legacy, say that it have a special conector for subaru... I do not understand anything... And finally the mechanic says that is not relevant... and i have to pay 30 euros for this.... i am thinking to buy a OBDII. This night i disconnect the batery all night, i hope this resolve my problem...
centrino replied to centrino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, the battery seems to be Ok, the car is very good condition, have 107.000 Km. when i read the codes i post it. Thanks again.
Hi! i´m from Spain, and i just buy a legacy 2.2 1997, all Ok. But when give me the car, the positive cable of the battery isn´t tighten, and one day later i see this problem, because the car go off... the problem is that the check engine light goes on when i running some miles, and goes off 2-10 minutes later. the engine and car is all ok. Can be a resset problem, or sounds more a MAF problem. Sorry for my english, and regards.
