Posts posted by Havnfun2
I have a 1984 Subaru Turbo 4 Wheel Drive ..2 door..Automatic..
Engine size 1.8
I have received much appreciated help here before when I needed a turbocharger and a fuel pump and I got lucky finding and purchasing them from members here and my Subaru has ran great since!!
Unfortunately I find myself having to ask for help again as it seems to be having a unknown problem again? Not sure what happened actually. The other day I ran all over town. We were having a snow storm and the car ran fine. I had stopped and purchased gas in the middle of the day and thats when I noticed the car began to act up. It started jerking and acting like it was going to die and then ran fine. I knew something was wrong but wasnt sure. I took my daughter and granddaughter home.. about another 10 miles. I then headed for home.. I'm about home and the car just shut off..like someone shut off the key..and then would not start..right on top of a bridge. I knew I had just put gas in earlier so it wasnt lack of gas. I tried to restart the car and it would not start at all. It just cranks over until my battery almost goes dead...but it will not start just like before when it was the fuel pump. My daughters boyfriend had just put the fuel pump on in about Aug..the pump was new btw ..anyway..it started right up and has run great until now. *Update* Just found out it is not the fuel pump.. filter.. fuses.. checked plugs getting spark to the distributer cap only..thinking new distributer cap and rotor?? Is there some other things I should be checking out as well?? I also was told you can interchange the fuel pump for this car with a Ford F-150 but I have forgotten what year they said?? I appreciate the input and all the help this site has given me in the past so..once again i'm asking for your help!
Thank You Again!!
Engine size 1.8
Unfortunately I find myself having to ask for help again as it seems to be having a fuel pump? or fuel related problem again? Not sure what happened actually. The other day I ran all over town and we were having a snow storm and the car ran fine. I had stopped and purchased gas in the middle of the day and thats when I noticed the car began to act up. It started jerking and acting like it was going to die and then ran fine. I knew something was wrong but wasnt sure. I took my daughter and granddaughter home.. about another 10 miles. I then headed for home.. I'm about home and the car just shut off..and then would not start..right on top of a bridge none the less and NO ONE helped me push this thing out of the way in the middle of this stupid snow storm! Grrrr!! Anyway.. I knew I had just put gas in earlier so it wasnt lack of gas. I tried to restart the car and it would not start at all. It just cranks over until my battery almost goes dead...but it will not start just like before when it was the fuel pump. My daughters boyfriend had just put that fuel pump on in about Aug.. I think..and it was a new pump btw ..anyway..it started right up and has run great until now. Just found out it is not the fuel pump.. filter.. fuses.. checking plugs now.. is there some other things I should be checking out as well?? I also was told you can interchange the fuel pump with a ford F-150 but I have forgotten what year they said?? I appreciate the input and all the help this site has given me in the past so..once again i'm asking for your help!
Thank You Again!!
Wow thanks for all that info..good things to know and hope it might help others too!! I really do appreciate it and looks like I have some reading to do!!
Here, I went ahead and did the search because i wanted to re read all that info myself.that shows you the how to, the part number, and plenty of pics. Youve got the option of going to a junkyard and finding a Ford (mostly pickup trucks, but there was some talk about a crown vic i think? i dont recall, pickups are a plenty anyhow) and having 34666759375 of them to choose from instead of only one rusted out burned up shell of a soob for a change... and you could get it for 1030 bux, whatever your yard charges.. or go to napa and get it for what is again a debatable price, but far less than 138 for the real soob piece. the beauty of it is that it mounts into the stock bracket like a charm, you just need to make sure you plumb it well so the lines dont kink. Its best to get a hardline 90 degree elbow, apparently, then put your fuel line to the engine onto that. but its a simple transplant.
using ford parts on a japcar?!!FrankenSoob!
I have a 1984 Subaru Turbo.. 4 Wheel Drive..fuel injected ..2 door..Automatic.. Engine size 1.8 Anyone out there have a fuel pump for this vehicle or have access to a fuel pump at a parts store at a resonable price??? Unable to find one local for fuel injected for less than $138. They do have one for this year car...for the price of $64..for those in need of one NOT fuel injected.
Your Help Is Much Appreciated!
Tina
Thanks for the info.. will try that tomorrow and see how that goes. Checked with auto parts here and found the fuel pump to be around $130 - $160..sound right?? Found one for $64 but my subaru is fuel injected and it wasnt the right one unfortunately. Anyone out there have a good one for sale???
if you have an air compressor, try disconnecting fuel line from pump outlet and then also under hood where it goes into the fuel intake.. and blow through the line in the car, make sure its not clogged too..cant hurt, and it rules that possibility out
Try changing the fuel filter. Did he just check the filter or changed it? aba4430
He just took off the fuel filter and blew threw it didnt seem to be clogged. When he first took it off it had a lot of pressure and gas flew out of it. He then took off the lines and we started the car to see if any gas came and nothing so he headed for the fuel pump.
Engine size 1.8
I have received much appreciated help here before when I needed a turbocharger and I got lucky finding and purchasing one from a member here and my Subaru has ran great since!! Unfortunately I find myself having to ask for help again as it seems to be having a fuel pump? or fuel related problem. The other day I ran to the store the car ran fine. I came out it started fine got about a block from the store and it starts acting as if it was running out of gas (like it was starving for gas). It stalled out and then would not start..I knew I had just put gas in the day before but thought possibly maybe it had been syphoned out because of reports its been happening in my neighborhood. So I call my daughter she comes.. but by the time she comes I try to start it again and it starts up kinda shaky at first..then increased to full power so I ran to the nearest gas station. Put in more gas just in case it was out or something. Started up just fine and I thought ok my gas must have been stolen...then I get about a block and it starts acting starved for gas again ..stalls out then would not start at all. Had to be towed home. My daughters boyfriend had checked filters and fuel pump and then put fuel directly into the car with nothing connected.. the filters etc.. it tried to start right up. After checking filters and fuel pump he believes it might be the fuel pump..but when he checked it again it acted like it was working and he could hear it and gas would pump out the line under the car by the fuel pump..but then try again and it wouldnt work. He said the fuel pump acts like it has a short or something. So my question is..is it the fuel pump and should I just go ahead and change the fuel pump or is there some other things I should be checking out as well?? I appreciate the input and all the help this site has given me in the past so here I am again!!
Thanks Again!!
I found this web site for Subaru recalls and technical service bulletins. They charge to use it and I havent done it as of yet.. but I too need help with my turbocharger..its in the car but has extra lines were not sure where they go. Here is the address.. and maybe it will help you...
http://www.alldata.com/TSB/55/84555202.html
I seem to be having trouble explaining myself........ill try again.I've just reconditioned my ea81t, and its almost ready to go in. It had the vf2 water cooled turbo retrofit done, and the odd plumbing as described below, which may or may not be for a reason.
I also have a spare intake manifold off another ea81t that didn't have the water cooled turbo, and didn't have the wierd plumbing. Its easy enough to add the turbo cooling line onto the thermostat housing of this manifold - no problem there.
I would rather use the above mentioned spare manifold, since it is already nice and clean, and the coolant fittings are in much better condition.
I just want to know if other cars that had the water cooled turbo retrofitted also have this odd plumbing as well.
If they do, that would indicate that it was necessary due to the dash gauge temp sensor being moved. If that was the case, i'd have to modify my spare manifold to accept this setup.
If they don't, it would indicate that it was simply someone being lazy, and i could leave things as they were from factory (my preferred option).
I'm not saying anythings "broke", i just want to know whats going on.
What would be perfect, is if i could find a copy of the service bulletin.....
Thanks guys.
I recently bought a new Turbocharger for my 1984 Subaru Turbo ..4 Wheel Drive ..2 door..Automatic.. Engine size 1.8..IHI Turbo. My old one went out and I was lucky enough to find a new one for sale on here and bought it. The problem is..it is exactly the same as my old one.. but it has 2 lines coming off of it that were put on when there was a recall/upgrade. We have the turbo in the car now.. but are unsure where the 2 extra lines need to be hooked up.
There are two lines on the side of the turbo.. on top of each other..one pointing up and one pointing down. Any help with which one goes where would be greatly appreciated as my daughters boyfriend isnt sure what to do now and we have found no information on the change over. Thank You... Tina
I bought a new Turbocharger for a 1984 Subaru Turbo 4 Wheel Drive ..2 door..Automatic.. EA81. It came with the recall/upgrade attachment lines.. I need to find out what I need to do with those extra lines. If anyone can help me it would be greatly appreciated.
I am 45 minutes north of Vancouver
Where in washington are you? -
Thanks for the information! I'm glad I found this site as this is the first time I've actually been given some helpful ideas as how to get back on the road again!
you can retrofit an ea82 turbo. you will have to make water cooling from the heater hoses and tweak the oil lines.you will need the downpipe with the ea82 turbo. the bottom of the turbo will bolt onto ea81
you will have to mix and match the right pcvs.
get the inhtake boot with the turbo you could make that fit also
ea82's will be more plentiful
Thanks! Any help would be greatly appreciated.
I'll try a wrecking yard just a couple of mile down the road from here....i knwo they have a couple of subes but im not sure if any are turbo. -
Thank you for the info... I wasnt sure if they were interchangeable with another model .. good to hear I might be able to go that way.
Yes, they are expensive, my one had a new one from a subaru dealer put on just before i bought it, cost the guy NZ$1500! (US$1000ish).The good news is that you can use the turbo off a later ('85-'89??) model car, with the ea82t engine (as opposed to your ea81t) with only mior modifications. THey should be much easier to find.
I found this information on the turbocharger..
Turbo Spec. VF1
Serial No.RHB5 15674
Parts No. 420637050
Side of the case it says...IHI Turbo
How much you asking for the ones you have?
I have 1 or 2 available, and I'm in western Wa(Sumner area). -
Hi all..
I'm new to this posting stuff as you can probably see. I have a 1984 Subaru..1.8 L ... 2 door... 4WD Turbo. The turbocharger has gone out on it and I am having a lot of problems finding one at a reasonable price or a rebuild kit or someone to rebuild it for me. This car is all original and runs great. Not having it running has been a real pain for me. I have searched all wrecking yards and auto shops for information trying to remedy this problem. I found this information on the turbocharger....
Turbo Spec. VF1
Serial No. RHB5 15674
Parts No. 420637050
Any Suggestions??? I would appreciate any help on how to get it back up and running and on the road again.
Help Needed Again!
Posted
Exactly what we're going to do tomorrow.. changing it all..hoping it works! I dont know how long since they've been changed.. another reason for doing so..keeping my fingers crossed! As for the trade.. I'm thinking..I'm gonna give it back to my daughter and buy me something brand new!! The dang thing will probably run forever after all the money i've put into it lately..that would be my luck!
