car died won't start
my 2000 legacy just died, lost power engine turns tries to start then nothing. pulled codes p0170, po325, po133. anyone have any ideas?
fuel trim malfunction
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreplaced on 2 other times same side, but had a code for it...right side of vehicle. you think maybe the other sensor is ready then?
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2000 legacy gt 2.5 limited, 135000miles. P170 code.
anyone know how to troubleshoot p170 code fuel trim malfunction bank 1?
timing belt replacement
my 2000 legacey just went over 100k miles. the book calls for timing belt replacement at 105k. any body out there ever have it done. know about what it should cost? thanks.
terrible noise
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the feed back it is much appreciated. ed
terrible noise
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hear and feel it in the front. 96000 miles I did shake the tire while up and feel a little play. Maybe 1/4 inch.
terrible noise
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI checked the backing plate, cleaned the brakes and lubed the pins and areas of the pads and shim. when I straighten out the wheel(while driving) the noise goes away. when I go into a turn I hear a sqeeking and feel vibration and scraping noise. Its drivin me nuts. I hate to But I think I might take it to the dealer. Thanks for the feed back . ed
terrible noise
my 2000 legacy makes squeky noise when i make turns at any speed above 20mph. could it be wheel bearings are there wheel bearings or hub bearings?
drive axle rplacement
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you for the help, I drop out the ball joint and sway bar, all went together well. putting the ball joint back in was tricky but i was able tto do it with the help af a floor jack. thanks again.
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI 'll give that a try, thank you fo r the advise.
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes , but there dosen't seem to be enough room to slide out the axle from the hub
edjhover replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've removed the axle nut, and the diff side pin and tie rod end and the axle is loose at the hub and diff. but there doesn't seem to be enough room to slide the axle out
hello everybocy, this is my first post. I'm trying to replace my front pass side axle and it won,t come out. I have everything off inc. tie rod end, it seems the axle is too long to remove, any suggestions? thanks
edjhover
