AussieIan
Posts posted by AussieIan
You're asking about central locking, but talking about a remote which suggests a keyless entry problem. These are separate systems in the car. Generally, Keyless Entry means just that. You have a remote to lock and unlock the car allowing you to enter the car without a key. Central locking systems generally use the driver's door lock as a "master" lock. Essentially, the driver's door lock actuator knows what position it is in. When its position changes, it then tells all the other doors in the vehicle to be in the same position.
So...when your car is misbehaving, what does it do? Does it fail to unlock from the remote at all? Does it only unlock the driver's door?
Sometimes it will lock with the remote and then refuse to unlock and vice versa. Its totally unpredictable. It will always lock/unlock with the key.
The car suffers from intermittent operation of the central locking. Basically sometimes it works the it wont. I have replaced the battery in the remote but this made no difference:-\
Thanks Guys, the cable tie solution seems to be the go.
Is there a problem with using a hose clip to seal the gear box side of the rubber boot rather than the thin S/S bands on the drive shaft. Its just easier to tighten with the shaft still on the car. I'm worried about the balance. Rgds Ian
Try a tank of premium fuel
Exactly the same symptoms as mine, and it was the starter contacts. Felt really stupid after having purchased a new battery which was triple the cost of a pair of new contactors!
Sticking stabiliser rubbers can make some very unusual clunkng noises, if the rubbers have been replaced suspect them
Some do have some very strong views about cleaning TB's including Josh who really does know his stuff. Anyway I went ahead cleaned mine anyway, I bought new gaskets for the TB to manifold in case I broke the old one. I removed it, there are some pesky water hoses and other bits and cleaned with with brake cleaner because it does not leave a residue and also cleaned the IAC valve with brake cleaner according to Josh's recommendations. The cars driveability certainly improved. Whether it was due to the TB or IAC is debatable. I must say the TB was not nearly as badly gunked as I was used to seeing on my V8 Commodore. I also reset the TPS sensor after I reassembled everything and it was quite a bit out. So whether you clean it or not is your call. I'm inclined to think it they do not cleaning regularly on Subes.
Fair enough, and at least you know its in the tank. Ive heard many stories of operators forgetting to turn pumps on when blending gasoline etc. Have you noticed a payback for your investment in the aditive? I've only done 600km since changing to premium, so far it appears the gas mileage has improved a little but its too early to tell. Cheers
I think it is probably cheaper just to use premium with the additives already in the fuel than add it, where is the cost benefit? The fuel quality has plummetted here as well, the addition of ethanol is being blamed rightly or wrongly.
I just gased up the other day, but will try using higher octane on the next tank (as painful as that will be on my wallet). I do use the better brands, so I'm not concerned about actual fuel quality, but octane may do the trick. I suppose a can of octane booster would answer the question sooner.
According to my mechanic its not just the octane. He has found that engines running premium fuel are cleaner, from the fuel injectors, heads even the exhaust system and this is the real benefit. I'm trying it my Sube, so far insufficient k's to see if any real improvement in gas mileage, but the hesitation has gone. BTW someone advertises a add on which smooths the signal from the knock sensor and cures a lot of hesitation problems. Might be worth a look if the problem persists. Cheers
Did you refuel during the period in question. With sky rocketing fuel prices here in Australia we also seem to have plummeting fuel quality, I was having similiar problems to you until on the advice of my repair shop I went off the discount regular fuel and went to premium unleaded. The difference was immediate. Its worth a tank to eliminate the possibility!
Some time ago I found a Subaru Tech bulletin on a modification to stop the wind whistle from the front windows, it involved putting spacers between the door metal and the triangular pieces that support the rear view mirrors. I saved this paper and other related papers to my hard drive but unfortunately lost the lot. Any one any ideas. I really need to fix that whistle!
Totally agree split boots are useless. If your not getting any clicking on full lock turns just replace the boots. Subes are very easy to do thanks to some thoughful engineering. I did mine in about 3 hours both sides. The boots I purchased had a pack of grease with the boot, wear plastic gloves when your handling the grease it really gets into the pores of your skin.
When the motor is heating up gases and other things are being forced via the leak into the cooling system because of the difference in pressure. When you turn the motor off things cool down and coolant is sucked in via the leak and decreases your coolant volume, the coolant that has been polluted by the first step. You probably have a faulty head gasket(s). Either way urgent attention is needed. Your oil probably looks terrible too!
NGK Iridium for me. I have done 30K since I changed from std plugs and my mpg's have not changed nor has the performance. I figure the less you do to an alloy head the better.
The grease in CV joints is usually a MoS2 based grease. Its usually not all that waterproof because if a boot gets torn the grease will be washed out on wet roads and lead to rapid failure of the joint. In Australia the replacement boot is supplied with a packet of the grease. If its still clicking and the boot is intact and the joint is packed with grease I suspect your CV is not worn worn out and the clicking may be coming form elsewhere. Good LuckWhat kind of grease is used in cv joints? Just an all purpose waterproof grease? I still get a clicking sound from my right front. And it seems to only be when it's cold. Could the grease in the cv boot be reactin to the colder weather and not doing it's job as well?Once the weather warms and the snow melts I'll pull the wheel off to affirm it's not a stuck caliper. And I'm pretty sure it's not a bearing issue. But whatever it is it's bugging me.
Hi people. My front suspension bushes including the sway bar bushes are quite worn. Are they a pain to replace? Do you need a press? Do I stick with rubber or go to nolathane. Any feedback greatly appreciated. Thanks Ian
Subes like thin oil and they like clean oil. If not changed regularly you end up with very noisy tappets. I followed the Haynes manual lub recommendations on tranny oil and have had no problems. Josh did have a complete owners handbook for a Legacy on his website http://www.surrealmirage.com/subaru if you have not got a handbook. You can't go wrong by following that. Cheers Ian
Hey all, I'm having no luck,now my steering rack boots are filling up with ATF. Does the Auto transmission stop leak from Wynns et al do any good in this situation or must I rebuild.:-\
Well the clonk has beeen discovered and its a first as far as Pedders Suspension are concerned. It was the rear windscreen which is that loose it is moving up and down and clonking against the body. Remakably it isnt leaking!!
Hmmm I assumed that when they replaced the shocks that they would check the mount and bearing plate, that sure sounds like where it is coming from. I removed the jack, spare etc from the boot to eliminate those sources. Also gave everything a good wiggle with no joy when the car was up on stands. Thanks for the replies. Ian
Yes Josh its all stock, and the bushes all look fine. Ian
I have a noise coming from the rear of my 91 Legacy (FWD). The shop said it was a shock absorber so I replaced both struts. Quess what the clonk is still there. I initially thought it was the board that covers the spare tyre bouncing about, but it wasn't that. Any ideas?
2004 Forrester Central Locking
Posted
Thanks Scooby
