rjohn
Everything posted by rjohn
  1. How much do you want for all of it?Do you have the controller?Where are you located? Robby in NC
  2. I don't if there more.If I leave it inthe Hi postion it takes two days to lower,but just the front. If i leave in the normal postion it lower in the rear in about twenty minutes. Robby
  3. Has anyone ever had a code 9 on self Dianostics for the air shocks systems.It is suposed to be the compressor relay.Could this cause the system to deflate in all different config,front one time then the rear the next.Robby
  4. My rear shocks deflate after the car is off. Could this be a control module issue or just leaks. they pump back up as soon as the engine is turn on. Robby in NC. Thanks
  5. I,m In Fayetteville.How much does cost to replace all 4.Robby
  6. Does anyone have cure for bad air shocks?Should I try to repair or relace them? Thanks
