Posts posted by badchicken425
Would this cause my problem?
Can I fix it without having to buy the whole assembly?
Fuel pump is pulled and there does appear to be a crack.
AAAAAAh0/B23hl2I8Ydg/w907-h510-no/20140501_161926.jpg
Adjusted the TPS reset ECU and it ran great for about a minute then started idling rough and died now wont start.
Checking the fuel pump next.
I Have a 2003 Subaru Baja 2.5 litre Automatic.That suddenly stopped running when I was pulling into a parking lot and is giving me a P0122 error code (Throttle position sensor circuit low input).
It will sometimes start idle high for a few minutes then start to idle rough and die.
I replaced the throttle position sensor same thing happens.
While adjusting the position sensor with the key in the ignition on position I hear a humming coming from underneath car. and when I attempt to start it will flash The AT oil temp light on dash.
Any thoughts or ideas?
Thanks, Badchicken425
I reset the ecu and got it started it idled rough then smoothed out after time but I could not accelerate otherwise it would die.
the error code and transmission light have now vanished
Yah i just found some brat parts on craigslist Thanxjust so you know, brat and coupe fenders are the same, might help in locating one. -
78 subaru dl wagon passenger fender
Needs front passenger side fender for '78 DL wagon
does anyone know where to get a 78 dl wagon passenger front fender please let me know badchicken425@yahoo.com
P0122 EOC
Posted
Thanks for all your help I was able to locate a fuel pump assembly for 100.00 on Ebay. I got it in the mail today and installed it in the Baja and the little Scooby Truck is up and running again. .
