Everything posted by RobJ426
Timing belt noise and slack
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's so true- also in the home appliance business.
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the tensioner pulley and belt I replaced last June. The bearings in the tensioner were ground down and was getting so hot it discolored the pulley and was frying the belt. At that time I replaced everything else too.
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks everyone. I changed out the tensioner with an OEM one from the dealer. Set me back $190 but it's back on the road and sounds great. I can actually depress the pin on the old one enough with my finger to line up the holes for the retaining pin. It lasted exactly 6 months and less than 6 thousand miles. The cast rim around the pin had been knocking against the boss on the block that the pin normally contacts and left an indentation in it. I'm beginning to agree with all of you regarding this current design of tensioner. The one I replaced last summer was only three years old and had about 35k miles on it. It was completely worn out. That one had been replaced by the dealer when I had all the front oil seals replaced. It used to be that as long as you had to replace the timing belt at a certain mileage you would replace everything else as good maintenence. Now it's become as long as you have to replace the worn out tensioner, you might just as well replace the belt. Thanks again- I appreciate the support.
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's weird, I must have deleted part of my post before posting it. Originally read: 1999 Legacy wagon 2.2 SOHC I was thinking the tensioner was not performing as it should the way the belt was just slightly slack. Looks like the likely culprit. It seemed strange it would have trouble in such a short time but I know anything can fail even right off the line. I'll pull it off tomorrow and take a better look at it. Thanks
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKragen
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEverything was Gates which I thought was a reputable brand in belts and accessories. One sprocket was OEM because nobody had it available. The OEM Subaru parts were 4x the cost and way beyond my grasp financially as my employer had just gone out of business and I've only been able to find temporary work since.
Subaru Saved Christmas
RobJ426 replied to MorganM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe used to live in Mankato and then for two years I had to commute daily from Prior lake back to Mankato while my wife did an internship at Hennepin County Med Center. I remember those days- arriving home in a dripping sweat even though it was 20 and blizzarding out. As long as I could see through the three inch unfrozen slot the frozen wipers were making and I could keep the car between the scattered farm mail boxes spaced about every 75 yards I knew I was still on the road.... I'm with you in spirit! Glad you had a safe Christmas.
.2 SOHC manual transmission 125k miles I replaced the timing belt on my wife's Legacy last June. I also replaced the water pump, the swing arm type tensioner and pulley and all the idlers. The bearings in the tensioner had gone bad and was overheating and cooking the belt. The belt was also rubbing on the manual guide above the crank sprocket. Everything has been fine. The last few days she said it was loudly growling when she started it and then it went away when it warmed up. She says she hears it sometimes at highway speed too so it seemed to be related to higher RPMs. I listened to it today and it sounded like the timing belt was flapping against something under the cover during fast idle. Sure enough as the idle came down it quieted down. I pulled the cover off the driver side and the belt didn't seem as taut as it should be or had been in June. I removed the large cover off the rest of the belt and reinstalled the crank accessory pulley/dampener. I started the engine up and it sounded fine and everything looked fine. As I increased the RPMs, the timing belt began to vibrate between the tensioner and thedriver side cam sprocket. The tensioner swung up and down a little bit too. As the engine reached about 3200-3600 RPMs the belt began to vibrate a lot and it also twisted at an angle while it flapped up and down between the tensioner and the driver cam sprocket. The tensioner swing arm and pulley moves up and down with the movement of the belt. Also as I increase the RPMs, the swing arm and pulley move up and then back down with the decrease. I assume some of this is normal to keep constant tension on the belt through the RPM range. With the engine off I can swing the tensioner pulley up maybe about an eighth of an inch by hand while pushing up on the swing arm. All the bolts seem tight and with the belt still in place I don't feel any other play in anything. Does this sound like a weak tensioner already? Is it normal for the belt to vibrate and move? I can't say I've ever run an engine and watched the timing belt so I really don't know what it should do but I do know serpentine belts for the accessories don't vibrate and move much. Is there anything else I might be missing? The 6 month old belt itself looks fine. No unusual wear, cracks or chunks missing. I suspect I'll be pulling this belt to look at all the components but wanted to pick some brains while I look at it.
Clock Spring???
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got home late tonight and it's cold and raining out....OK- I'm a pansy tonight and don't feel like going out in the dark to check the it out. I'll let you know what I find. Hopefully it's just a pad missing. If you own a 2nd generation Caravan/Voyager it seems to be about a 50/50 chance you will eventually replace your clock spring during the entire life of the vehicle - I don't know what the odds are with other makes but I would assume they're produced by a small band of companies and widely distributed. Anything will only flex so many times before it gives. For those who aren't sure how a clock spring in your car works, think of a tape measure and how it will pull out and retract.
Clock Spring???
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a five speed so I'll first check for the rubber pad. Thanks for the ideas. http://www.autocarepronews.com/default.aspx?type=art&id=79660&
Clock Spring???
The cruise has stopped working on my wife's '99 Legacy Wagon. The cruise indicator light comes on when you push the dash button but when you try to set it using the little paddle switch located at the 4 o'clock position on the column it won't engage. The horn still works and the air bag light is not on. I know with my '94 Caravan I used to have, if the clock spring went you usually lost everything with controls on the wheel including the airbag. I'm not familiar with how it works on the Subaru. Thanks for your help.
CEL Misfire Cyl #2
RobJ426 replied to subiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI should say I first replaced the plugs and it was good for a while with the restored gap on the new plugs. Once the plugs wore in a bit, the spark wouldn't jump again and the cycle started over.
CEL Misfire Cyl #2
RobJ426 replied to subiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy wife's 99 Legacy just got through that - it was the coil. Sometimes the code was #1 misfire, sometimes #2 and sometimes both. It was usually on a hill where she was laying into the throttle a bit - not getting a good fire with the extra mix heading it's way.
Ignition problems
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd guess their suppliers vary over the years but the ones I just bought from the dealer and were in the Subaru packaging read: *7mm HI-PERFORMANCE SILICONE SUPPRESSION CABLE* The boots matched the originals perfectly.
Ignition problems
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould have posted a follow up- sorry about that. Replaced the coil and wires with OEM ($200) and it runs perfect. First vehicle I've ever owned with DIS. Thanks for the help everyone.
99 Legacy clutch service
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't pull the engine, the manual just said the front had to be lifted a bit to get the right angle to remove the tranny. I'm near Redding so it's pretty far north of you but I appreciate the offer. I figure over Christmas break my 17 year old son and I will work on it since he's the one who shortened it's life while he was learning to drive. It was one particular third gear start because he forgot to drop it into first and didn't think he had time to go back for first with cars waiting behind him that really did it. He smoked it bad and it started slipping from time to time the next day at only 40K miles. He's learned so much helping me with these cars.... like if you abuse it, you get to fix it! Seriously he's becoming a pretty good mechanic. We'll take digitals as we go as I'm more used to removing traditional rear wheel drive transmissions on American made vehicles. I have changed out a half dozen half shafts so that's no big deal. I was just wondering if there were any special quirks with this particular job. Thanks for the info- I will check those parts for sure. I was planning to have the flywheel looked at and either resurfaced or replaced. What is the discussion on that? I suppose some feel it should always be replaced? I know some vehicles that's pretty standard advice so I'm open to any comments on that subject. Who carries Excedy clutch kits? Any major national chains? Thanks again- I really do appreciate the advice and tips.
I do all my own service and repairs but have never done a clutch on an AWD Subaru. I glanced through the manual and it looks as though the engine has to be lifted a bit and of course removal of exhaust components, linkages, front half shafts and rear driveshaft. I haven't looked into how the "Hill-holder" mechanism plays into all this yet. My questions to anybody who has done it on one of these vehicles- Are there any "Special tool # XYZ"s that are needed and in general what can go wrong? In other words are there a lot of minute adjustments that are critical and hard to accomplish, parts that like to jump out and not go back in place...etc, etc or is it pretty straight forward for an active backyard mechanic? '99 2.2 Legacy Thanks
airbag deployment
RobJ426 replied to cowboyFunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a couple on ebay now. http://cgi.ebay.com/ebaymotors/Subaru-Legacy-Outback-95-98-AIR-BAGS-SET_W0QQcmdZViewItemQQcategoryZ33719QQitemZ8010993887QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/ebaymotors/1997-Subaru-Legacy-Outback-Air-Bags-Control-Module_W0QQcmdZViewItemQQcategoryZ33719QQitemZ8011478802QQrdZ1QQsspagenameZWDVW
Ignition problems
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have to say my plugs all looked very good. When I replaced them the first time I had problems, the electrodes were slightly rounded as you would expect from plugs due for replacement but the color of the burn was perfect. That nice tan with no deposits at all. Sounds like timing or maybe a really lean mixture on those fried plugs. This is my first vehicle with DIS ignition and I've been learning over the year we've had it so there may be conditions to cause that of which I'm not aware of.
Ignition problems
RobJ426 replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks much. I replaced both the coil and the wires today with OEM parts and so far so good. No codes and the idle is smooth. Thinking about it makes sense- it ran fine for a couple weeks and it was dry all that time. It rained hard on Friday and Saturday for the first time and Sunday it was misfiring again.Thanks again.
Ignition problems
A couple weeks ago my wife's 1999 2.2 Legacy Wagon began running rough, bucking and then the check engine light began blinking on and off on her way home. I ran the codes and got P0301-Cylinder 1 Misfire Detected. I changed the plugs as they were probably overdue anyway and planned to change the wires but nobody in town had them in stock. Since then I haven't gotten around to it. After the plug change it ran perfect until today when it all began again as before. I was out of town so my son ran the codes again and got P0301 (#1 Misfire) and P0302 (#2 Misfire). He checked the wires and found that only #'s 1 and 2 wires were corroded green where they contacted the coil. #'s 3 and 4 were fine. he cleaned them up and it helped a little but it's still misfiring and throwing codes. I will order wires tomorrow and replace them but I also want to check the coil. The problem I have is that the only manual I'm able to find local is for 1990 to 1998 Subarus. I was going to check the coil's primary resistance but the number of terminals on the coil's plug don't match from the manual to my 1999 model. The book says to check resistance between terminals 1 and 2 in order to check the 1-2 coil pack and to check the resistance between 2 and 3 to check the 3-4 coil pack. My coil has four terminals not three as the manual shows. I have a Diamond coil. Does anybody know the procedure for checking the primary resistance on a four terminal coil? I'd also like to know the correct value range to look for as I don't trust this manual to be correct for my year model. This manual says the range should be 0.62 to 0.76 ohms. I did check the secondary resistance and got 12.4k-ohms between 1 and 2 and 12.4k-ohms between 3 and 4. My manual calls for 17.9-24.5 on a Diamond coil but again I'm not sure I trust the manual. Can somebody also supply the correct values for this. Thank you much, Rob
