awdbiped
Everything posted by awdbiped
  1. Issue found, Turns out the clutch lever is either bent or broken causing it to hit the side of the opening on the bellhousing, could also be that the clip came off and is allowing the lever to float. So the release barring is only contacted on one side, allowing to only extend part way. It is time to pull the trans. Has anyone tried changing the clutch by moving the motor forward on an OBW? And if so can you get to the rear main seal to replace it that way?
  2. Hey Guys, i am fairly new to this board and this is my first post. My problem is with my 1997 outback 5sp w/ 125,000miles Story goes, about 3 weeks ago the clutch stopped returning to regular height. It was a sudden occurrence, fine one moment and then just stopped. While driving it home the clutch began to disengage less and less until it got to the point where I was driving without disengaging the clutch. Since then I have done the following. Replaced hoses, no change in pedal Replaced slave cylinder, no change Replaced master cylinder, no change Bypassed clutch damper, slight change, but still not returning Each time this was done I completely flushed the fluid through the system while bleeding. And made sure that there were no bubbles in the bit of hose I was using. For my next step I removed the boot around the slave cylinder while the pedal was at max compression, so the slave cylinder was at it's max extension. I saw that the internal cylinder was extended about 5/8" past the edge of the outer cylinder. My ultimate question is whether or not the next step should be to replace the clutch, and supporting items? It is costly and time consuming, and I am poor. So any other ideas or anyone that might have experienced this already, to either confirm or tell me I am going about this all wrong?
