DMOR319
Everything posted by DMOR319
  1. Guys Finally was able to get around to fixing the car. You were right it was a timing problem. I had to trplace the timing belt auto tensioner. Realign the timing belts as they are at 90 degrees as opposed to being 180 degress in normal cars. Put cover back on and the car started. Once again thats to all of you for your help. Regards Dave Morris
  2. Timing belt was changed at about 60000 miles about 3 years ago. I replaced the spark plug wires still no go.
  3. The timing belt was changed at about 60000 miles. Thanks for your replies. And have a happy new year
  4. The timing is at 10 degrees if the timging mark is correct a rather small notch in crank barely noticeable. The spark plug wires were replaced. Atiming light was used and my mechanic said there seemed to be two sparks he checked the wires and he thought his timing light was broken that was when the wires were changed. He said that the timing should be at 10 degrees. He is also stumped Any Help appreciated.
  5. Weather was fine. Replacedthe CRANKshaft sensor with a subaru part.and replaced the camshaft sensor with the one that was used in the Crankshaft sensor. Still have a good spark and fuel is ok. still not starting. there is a popping sound like it almost wants to start when the key is turned off. Commpresion has not been checked hope to do that today. Any help greatly appreciated.
  6. Hi Josh I also replaced the PCV valve and the battery has been disconected. I ordered a new crank sensor. And when the weather gets better I will replace the sensor and try it again. Thanks Dave
  7. My 1993 impreza L wont start. It started with the Check engine light coming on. The fan would run as soon as the key was turned. Coolant sensor was replaced. cleared up the fan problem. Still no joy in starting. There is puls e in the injectors. and a double spark from the spark plugs. the crank shaft sensor was replaced with a camshaft sensor minus the sleeve would this have a bearing on it not starting also how about changing the ignition module? any help gratly appreciated. Dave Morris
  8. Hi I am a new member. I am looking for some technical help. My daughters 1993 Impreza L won't start. It turns over but will not start. Timeing belt was checkedit seems ok. Crankshaft sensor was changed coolant temp sensor also changed.There is a popping sound when key is turned off. any help appreciated.
