Posts posted by LEGACYTUNER
yeah, any takers on this? im having that same stumbling problem on my 93 5mt loyale wagon it has 100,843 miles on the odo.
Problem solved:drunk:
To my knowlage, the 88gl and 93 loyale should be the same car (both l-series wagons) ... Am I wrong?
Very true, ive been looking forever and found one for about $70, pretty steep but its nice.
bump again
how much? does he have paypal?
and what kind of condition is it in?
sorry for all the questions:banghead:
is it grey?
My loyale is an ea and not an ej
does anyone know if an 88 gl wagon retractible cargo cover will fit a 93 loyale wagon?
just want to make sure.
Detroit Lakes MN, is definitly the suby capitol of the U.S
at any one time you can count over 10 in any parking lot at any given time
the population is around 8k and nearly every other family has between 1 and 5
there are really hundreds, i love living here.
take a normal candle, one without too much of the scent or coloring, although i don't think it matters, and while its running, BE EXTRA CAREFUL, now that the caution is out of the way, hold it to the side of the V the part that contacts the pully >V< that will give it a good coating, and help it from squeaking too. don't go too thick, if you see it thats too much, just hold it to it for 5 seconds or so.
A bar of soap also works good for this;) . I prefer irish spring.
I'm a little confused, When and where?
The first should work for me also, i think the g/f will approve.
I would like to see an adapter from the 4 bolt to the 5x100 bolt pattern, that way we could use the 14 15 16 inch wheels that subaru already produces, and i would assume that 4 adapters would be much cheaper than 4 wheels to fab, ask him what it will take to make these, i'm sure almost everyone who offroads older subarus would be interested.
highly unlikely but could the previous owner have done a transmission swap?
I doubt it, the car has only 82k
I'm wondering what the fuseholder is for on the pass side next to strut tower
i have a 93 loyale with push button 4wd 5 spd, i know that on the auto trans legacys that i once owned this would disengage the the rear drive. Any takers on this one?
27th - 30th would work best for me, 31st and 2nd are possible, and definately NOT the 1st
The first is called national hangover day! I plan on having a bad headache.
Hey guys, Sunday the 2nd would be good for me, where would we meet?
I would have hooked up with you guys, but i had alot of family here for T-Day
and through the weekend, I will try next time.
My 93 loyale wagon seems to be really doggy in reverse when im in soft terrain such as sand or mud and in 4wd, i thought that reverse was the lowest geared? has anyone else experienced this?
Welcome to the board!, hubcaps and mirrors are on ebay right now just search for subaru loyale and you will find them.
Welcome to the board!, I'm in Detroit Lakes which is fairly close to Grand Forks
All the connections look good and as for the headlight it is brand new, when switched to the other side it works great
look at the headlight harness, any corrosion? or signs of a melted plug? there are three contact points on the headlight plug you can use a small screwdriver to bend them so there is better contact with the bulb.
EA82 Radio Questions
Posted
this should work for you. i use the same one
http://www.installer-data.com/item/display_item.php?it=99-8900
