Everything posted by gritle
emergency engine problem help!!! 98 legacy.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo really How big of a deal is a blown head gasket $$$ wise. Also if that is the case am I able to move the vehicle and is it a sign of serious damage and death of my car?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnow when I start it it seems to kick and sputter. If it is the head gasket will I be able to drive for the next day or two?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany thoughts I'm freaked out
So I'm driving around town to pick up some packages and realize that there seems to be some oil burning. This haas been a minor problem for awhile due to a leak which drips on to the exhaust manifold, I usually don't think much of it. Then I noticed that my heat went out. The temp gauge is topped out and the smoke keeps coming. Soon i notice my oil flash a bit. It rarely if ever has done this. I stopped to put oil and and noticed that it seemed to be dripping out at a steady rate. i also added coolant since the reservoir seemed low. Now when i park my car as I get home I stalled it twice parallel parking and the second time I started it I had the most trouble getting it to turn I;ve ever had with this car. Thoughts... suggestions? Am I in big trouble. It is a manual transmission.
clutch throw out bearing sound?
So I had my clutch replaced about two weeks ago this friday. It woerks fine but I notice a sort of whirring or whistling sound. It is not always present and when it is if I press on the clutch just a bit the sound is gone. I've spoken with the guy who did and he said he could help but didn't seem to think it was a concern. Shuold I be worried about future complications with this?
tach speoodmoeter ratio?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it was some pretty bad spelling. I had it done by an independent fellow. I just realized that even a bit of pressure on the clutch pedal will cause the sound. I think I'll survive. thank for the tips. oh and my car didn't come with a manual. I drive a 98 legacy l seres wagon. no idea on the size of the tires.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the clutch replaced on friday. My question regarding the speedometer tach ratio is whether or not I'm losing gas mileage. If I'm at 70mph is it right for the RPMS to be around 3k?
I just had my clutch replaced and am curious of what a good ratio for the speedometer to the tachmometer should be. I wonder if I am losing MPG this way. Currently when I am at about 70 mph my rpms are about 3K. is that rights? Also there is a bit of a chirp or ringing sound coming from ny new clutch is that common?
trying to explain the change in my car
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it's cool I'll call right about 11 if I could get your opinion.?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso I should get quotes and a credit card?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou should have mail.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI mean address?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXaddress I've got them ready to send.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think this thing works. what should i take a picture of? well I uess I'll take a couple. I'm not sure if I can link 'em though.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm? there is nothing in the middle like in that photo. I looked at the clutch pedal and it seems to engage a spring with some levers attached to a cable the goes through the fire wall I think.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat the one. If you look back from the windshield fluid box to the yellow cap a bit to the left it is the brake fluid box. then to the right of that is the black assembly i think is the cylinder but I know it isn't. huh?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat would be helpful as my car did not come with an owners manual. I kind of got shafted when I bought this as they didn't tell me it was prior salvaged. I took it in for alignment shortly after buying it and was informed the sub frame was cracked. long story
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa few more diagnostic questions....? If when I down shift the car clearly seizes might that be an indication of low clutch fluid? also what I've identified as the clutch cylinder does not appear to be a screw off cap. it has two or three hoses going into it. should that be the case? also I have not noticed any sort of smell. I can be in fifth gear at about 60 mph with a bit of acceleration and no changing gears I still get revving. <<just an observation.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis a better course to replace the clutch or sell the car?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany thoughts on how long an aging clutch can last? is cold weather much of a factor? will my car ultimately not move? what is the outlook?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno problem the help is greatly appreciated.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am not a woman just not a car buff. though if there were suggestions in the area I'd be happy to entertain them.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso I just drove around the block. there seems to be a bit of freeplay. However at a stoplight I let the clutch out completely and the car slowly moved forward. still no luck finding the clutch cylinder. I'm beginning to see a worse case scenario here.
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhere is the clutch cylinder? I just went to check. I have found the brake fluid reservoir. There is s small black cylinder between the brake fluid reservoir and the windshield washer fluid reservoir. however I don't know how to get it open. does the car have to be warm in order to accurately check it?
gritle replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds like I have hope
