Everything posted by scorch
'96 Outback ABS weird issue
I've got a '96 Outback Legacy and the ABS light just came on. I shut the car off and continued to hear a hissing, whirring sound from the engine compartment. I opened the hood and the sound was apparently coming from the hydraulic control unit (apparently just the hydraulic control unit, not the control "module," which according to Haynes is located in the dash in this car). This is located in the front passenger side corner of the engine compartment. It sounded like a pump going on and on, even though the car was off and the key was out of the ignition. I had to disconnect the wiring connector to the unit to get it to stop. What is likely going on, and what are my next steps? Thanks for helping.
off-book Legacy maintenance
scorch replied to scorch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou seem to be contradicting yourself. You recognize that subaru was wrong about ommitting a tranny fluid interval, yet don't believe that they could possibly be wrong about ommitting an interval for the throttle body. I've seen it in other manuals as a 60K maintenance item, but considering how easy it is and how often they get varnished with gunk, I think 30K is not unreasonable for the sake of preventive maintenance. If you saw how much gunk was on mine after 90K of mostly highway miles you might not begrudge a shorter maintenance period. Well, nobody's saying to do the job wrong! And of course you'd want to use throttle body cleaner to clean the throttle body to avoid problems. Makes sense, doesn't it? Besides, Subaru's TB is not coated anyway. There are no seals around the TB shaft and besides, if you use a rag and a Q-tip to clean it it's not an issue anyway. It's about as easy to do this job as it is to do an oil change, for the price of a two dollar gasket, with more immediate and noticeable improvement in performance if it's even a little bit dirty.
I was noticing that in the Haynes manual, there is no recommended interval for cleaning the throttle body. This item should be done every 30,000 miles to keep the idle smooth and the fuel injection efficient. Is there anything other maintenance particular to these cars that should have been included as a periodic/preventative item that isn't in the book?
Steering gear
I've got a '96 Legacy Outback. I was noticing some front end clunks, and I poked my head under there over the weekend to see if there was any looseness. Of course it's very difficult to put enough force on the components to reproduce the problem, and the only thing I noticed was some looseness going into the steering gear. Is this normal, or should it be as tight as everywhere else? There seemed to be some clunking coming from both sides - right where the steering gear boots are. So if I need to replace something, am I looking at replacing the entire rack, or is there an inner tie rod end behind the boots? Also, how should I proceed when even trying to jerk the wheels around with all of my strength doesn't really reproduce the sound that I'm hearing on the road?
Outer CV boot
scorch replied to scorch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm pretty sure it was fairly recently, within the last six months. It's not a huge tear, but it's not small either. I'm going to take a chance and just clean it really well and regrease.
Outer CV boot
I need to replace the outer front CV boot on my '96 Legacy Outback. Do I need to take the whole axle out, or can I just take it apart at the outer CV?
poly bushings
Does anybody know where I can get some poly control arm bushings for my '96 Outback?
Bike rack for outback, help needed!
scorch replied to willmartel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat do you mean by "tongue weight?" I thought that term was specific to trailers.
Suspension upgrades
I'd like a slightly more sporty (but not too stiff) suspension in my '96 outback wagon. The front end is starting to clunk so I'm planning on rebuilding it myself - bushings, tie rod ends, ball joints, & struts. What are some good options for aftermarket strut inserts that would give me tighter cornering without my wife complaining that it's too harsh? And secondly, is the strut job pretty easy? Does the top nut or anything else require any special tools?
Shift indicator light
Looking at the Haynes manual, it's not really clear if I need to remove the center console in order to swap out my burned out shift indicator light on a '96 Legacy Outback. Do I have to take the console and/or the shift knob off, or is it accessible by just prying off the cover? I would just pop it off to find out, but I'm kind of superstitious about interior plastic - I've broken enough pieces over the years to want to minimize what I'm doing with it. Also, I want to budget my time tomorrow evening.
why lots of 2001 Outbacks for sale
scorch replied to lynjohn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost people are not very good with money and make dumb consumer decisions. They are irrationally attached to warranties, they like to own cars when they have high rates of infant mortality and during the years of the most rapid and extreme depreciation. Their foolishness is our gain!
Thermostats???
scorch replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it was still the original thermostat after 150K, I'd say that's pretty impressive that it would last that long! You shouldn't try to push it much more than 50-60K without swapping in a new one, even if the old one is still working. It's an inexpensive preventative maintenance item that will save you a world of pain and $$.
Thermostats???
scorch replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles did the thermostat have on it? Even an OEM thermo won't last forever....
How I increased my gas mileage
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, I get it. Because you're threatened that I challenge your ideas and naivety, without any basis or knowledge you're taking a blind stab at my socio-economic status. Nice. One day you will learn that what Mommy and Daddy can shell out for you doesn't make you what you are in this world. (And at least I can spell "probably.") Again, more irrational thinking. That's like saying if oil did its job, there would be no need for engine rebuilds. Or if tires did their job, we would never need new tires. And I don't recall that anybody ever said they performed "flawlessly." We merely asked you why you felt that they didn't do their job of filtering the fuel, to which you have yet to respond with anything of substance. Because of the higher quality of today's gasoline, in fact there is much less need for injector cleaning, so much so that nearly all manufacturers have dropped this item completely from their maintenance schedules. Twenty years ago that was not the case. Clogged injectors were much more common. Today it is not uncommon for cars to last their entire service life without needing an injector flush. Nobody has suggested that over a long period of time, your throttle body won't see some varnishing, and your injector pattern could never become compromised. These things happen, but they're the result of high mileage, not fuel quality or inefficacy of the specified filter.
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat sounds about right. But for $200 I find it highly unlikely that the shop did a bench flush of your injectors, and cleaned your throttle body, which are the two most important items to do on high mileage engines that can see some accumulation of varnishing (and that has nothing to do with your imaginary "soot" or "dirty" gasoline in today's pumps. On that matter you are simply uninformed, and would find it difficult to substantiate your impressions (and by the way, merely repeating the claim is not the same as substantiation). But you obviously have more faith in your numbers than logic would dictate. Your scoop mod, especially, has about a zero chance of improving gas mileage, and if anything would only increase drag (to say nothing of dependability, as you will no doubt find out when the rains come again). Your choice of words implies that you think both things that you did were of positive benefit, and between the two they gained you four MPG. But the only thing that could have possibly helped was your injector cleaning. After all, five minus one is four, but that doesn't mean that the COMBINATION of five and one is four. And besides, you still have not explained how you got your numbers. As has previously been mentioned, unless you got these averages over several thousand miles, and either averaged out or controlled for influences such as driving conditions, driving speed, tail wind & head wind, grades, tire inflation, pump calibration, and several other factors, your numbers don't stand up to scrutiny. I don't know why you would ask me about my location, because that has nothing to do with it. Your beliefs in this matter are simply contrafactual, perhaps based in naive, vague political notions about the evil Republicans hell-bent on deregulation (this kind of ignorant bias is par for the course for today's college student, sadly). But there has never been more regulation on gasoline content than we have today, and in fact the quality of fuel (and other automotive fluids as well) is extremely high across all brands. Consumer Reports, among other groups, have done exhaustive studies to confirm this. And moreoever, the idea that today's gasoline contains "chunks" and "soot" that can magically pass through a Subaru fuel filter and clog up your injection system is laughable.
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNow you're saying there's soot in gasoline. You are an odd one. Remind me not to send my son to Penn State! Unless you have anything close to evidence to the contrary, why would you doubt that fuel filters will do their job of filtering fuel?
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPerhaps the point was to feel smarter than Subaru's design team.
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat are you referring to? Gas has never been cleaner than it is today. And besides, what did you think that little thing called a fuel filter was for? Is yours missing? If so, you should put one back in right now! If it's still there and you are replacing it when Subaru says you should, it would seem reasonable to me to assume that it's doing its job. I don't know what kind of "fuel treatment" you shelled out $200 bucks for, but the only thing of much importance that a garage can do along these lines is a pressure flush of your injectors (for high mileage vehicles, mostly), and that's going to run you more than $200. I'd be curious to find out what this "fuel treatment" actually was. Again, your critical reasoning skills are leading you to some hasty conclusions. Do you know what those "chunks" were and where exactly they came from? Do you actually think that "chunks" are a normal thing to find in gasoline? And again, do you think that your fuel filter is incapable of doing its job? The kinds of concerns about the quality and cleanliness of gasoline that you have seem to be based on nothing more than hasty conclusions drawn from limited and questionable anecdotal evidence. But even if gasoline was really dirty as a rule, the only problem it's going to cause you is some stalling every few years as your fuel filter clogs up prematurely. And as to your hood scoop mod, I'd be curious to know what your qualifications are to determine that such a change would be beneficial. Because given your posts on this thread, no offense I have a hard time believing that you are trained in the fields of aerodynamics and automotive science. I'm not saying this to be insulting to you, but to emphasize your flawed thinking so that other people reading this thread won't be misled by it.
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis point needs to be emphasized. If you're judging MPG on the basis of only a few fill ups, your margin of error could easily be a few MPG just on the basis of different fuel pumps being calibrated to stop at different levels. Throw temperature and driving conditions into the mix and you are flying pretty blind for determining MPG at home with just a notepad and a calculator.
scorch replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut you are not using your students' critical reasoning skills (do students ever even have those anyway these days?) if you think your scoop mod and fuel treatment are responsible for the difference. If I have a cold and I eat pizza and my cold eventually goes away, that doesn't mean that pizza cures the common cold. I can relate to your desire to get the highest MPG possible, but there are better things that you can do to get there than the two things that you mentioned.
Valve Adjustment?
scorch replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou didn't read very carefully. 97 and later models have a different procedure, but the procedure for earlier models is also in there.
Seafoam and Synthetic
scorch replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt shouldn't matter. But then, I wouldn't bother with the seafoam in the first place. It's not going to accomplish anything that the regular detergents in the oil will do anyway, especially if you go with a good synthetic. You're basically buying snake oil for your car, you know that don't you?.... It shouldn't matter which brand. They are all extremely high quality. You hear lots of scuttlebutt about leaky seals after you switch to synth, but that has not been my experience. Imagine being concerned that your oil NOT get rid of gunk in your engine! To the contrary, if it's so dirty that it's keeping leaks from happening, you want something to clean your engine ASAP, and just deal with the leaks when/if they happen. But again, the concern is really overblown to begin with. The one thing that you need to be careful of, especially if you decide to go with an extended service period with the synth oil, is that you get the very best oil filter that money can buy. No sense in sinking money into expensive oil and then trying to keep it clean with a cheapo Fram filter. Personally I'm on the fence about the synth vs. dino question. If you intend on driving the car till the doors fall off, you should switch to synth because it will indeed extend the life of the engine. But if you're going to sell it at 200K, I don't see any benefit to it. Because if that's the case, you're basically shelling out a lot more for oil for the benefit of the person you'd be selling the car to, the person who WILL be driving it till the doors fall off. It's certainly not going to effect the drivability or dependability of the car. But I use them because I'm really anal about getting the best stuff for my cars (I just wish I had the same attitude about my own body). On the other hand, for the fluids that have a long service period and don't get filtered, such as the diff and the manual transmission, I think using synthetic in those applications is a no-brainer. Do it.
Vibration on braking
scorch replied to mikeshoup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou thought wrong. Who told you that? It's incorrect. Your dad, of course, is right. He's always right, or haven't you figured that one out yet?
how's your Outback mileage?
scorch replied to mrfeh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow is your tire inflation? Poorly inflated tires are the one item responsible for the most wasted fuel. And it's one of the easiest remedies. Also driving habits (heavy on both pedals), AC use, and unnecessary loads. Just basics like that. Try cleaning out the throttle body. It's not on the periodic maintenance but it ought to be. And check or replace your vacuum lines.
Oops... front strut / suspension question
scorch replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy do you say that? There are a lot of scenarios where it would make perfect sense to pay more than the kelly blue book value of a car on a major repair item, if you intend to keep the car on the road for a long time, and especially if the repair in question (such as struts) effects its safety on the road. Cars are transportation expense items. They aren't "investments." (If you think of a car as an "investment," you get an F for financial smarts - I've got a bridge to sell you if you think a rapidly depreciating asset is an "investment"). It's usually not smart to consider the resale value unless you otherwise are considering selling it anyway. What does the kelly blue book value of a car have anything to do with anything? The more logical question to ask yourself is this: for the price of this repair, could I buy a car that is as good or better than this car will be after the repair? If the answer is no (and it usually is), then it's usually smarter to go ahead and get the repair done and keep you perfectly good car on the road. Unless, of course, you are using the whole issue just to "justify" spending gobs of money on something newer so you can have the new car smell and ego gratification. But that's a different issue entirely....
