jrrodger
  1. Hello; Good Tip. Does anyone know if the Imprezza 1999 model corner light will match the forester corner light? regards, JR
  2. I forgot to add that it is the drivers FRONT corner light
  3. Good Day; I have have the misfortune of getting hit in a parking lot while parked. As a result there are a pile of scratches on my fender and bumper. Also a corner light cover is broken on the driver's side. Fortunately none of the scratches have gone through the primer. Does anyone have any experience with what is best to do to replace this? I am not too sure that buying the $100 + CDN part from the dealer is worth it. I may be interested in doing it with aftermarket MOD parts (changing the passenger side if necessary.) I have a 1999 Forester S. thanks JR
  4. Hello; I have just gotten my car rust protected with an oil spray solution. After this process was finished by my mechanic, I found that my power locks became a large problem. The symtoms are: -turning on any electrical component in the car ie: turn signal, radio, heater causes the locking system to try and lock itself, and the "door ajar and dome lights blink on and off for a second" -the keyless remote on my keychain does not operate properly any more What I have done so far to try and clear up this problem: I have parked my car indoors to try and "dry-out" the electrical components. -I have run a hair dryer onto any electrical components I can see under the hood including the fuse panels. -I have pulled out the door lock fuse and put it back in (this seems to calm down the system a little) Does anyone have any suggestions as to what relay circuts I should look for to try and troulbleshoot this more? regards, JR
