andywatson
Everything posted by andywatson
  1. I've got the same problem. The driver's seat bottom has been broken since I bought my 98 OB Wagon used 3 years ago. Is it simple to swap the driver's side bottom with the passenger side? Also, has anyone had any luck with re-soldering whatever is broken down there?
  2. There are 2 options for getting your XM radio signal to your factory FM radio in the dash. One is using the wired FM modulator. This requires you get under the dash and put the modulator between the car antenna and your FM radio. You also have to provide power to the modulator. An easier method is to use Delphi's wireless FM modulator. It simply plugs into your cigarette lighter jack and a little box on the end of the lighter plug contains the FM transmitter which sends the signal to your factory FM radio. The only down-side is that the audio quality with the wireless modulator isn't quite as good as the wired version. But it's alot simpler.
  3. Yeah, I know I could cover it. But my Impreza has one of those compartments, and I really like it. I hate to cover up all that useful space.
  4. I'm looking for the little compartment that mounts under the stereo in the dash. I've removed the factory CD player, and now I've got a DIN-sized hole under the stereo that i need to fill. Does anyone know the correct name or the part number for this thing? I don't have any Suby dealers or junkyards nearby, and my internet searches keep turning up nothing. BTW, it's a 98 Legacy OB wagon, but I've seen these compartments in 97 Imprezas and Legacys as well.
