Rear tire outside wear
OK, after looking at that page from the manual again I think it makes a bit more sense. But, since I broke my ratchet last night trying to loosen the lower strut bolt I'll have to give it a while before I give it a try again (at least until i get my ratchet replaced by Sears, and get a real breaker bar again). Thanks all
Tire is not cupped, only the outside is wearing. I assumed rear alignment/camber issues, but after looking at it for a long while I am still not 100% sure that I want to attempt the pry-bar alignment technique. However that may be my only option, we'll see.
The car: 88 EA82 wagon, 4wd d/r etc etc... Rear tires are wearing super fast on the outside of the tire only. I thought maybe bad struts, but then I realized that would make it wear fast on the inside. Went to look at the alignment, and can't see if there is any adjustment that I can/should make. Suggestions? Any one? Beuller? Can any one tell me if fast wear on the outer edge of the tire is normal? I've only had the car about 9 months, and don't want to put new tires on if they are going to just get eaten through. Any helps is, as always mucho appreciated
Which Lift Would be best for me?
Sheesh, I thought I was close by the computer all day... Thanks for the quick replies, I have browsed the FAQ briefly,and will do so in more depth this evening. I shall be talking with SJR in the next week hopefully... Thanks for the tire info too, I kind of understand how height/lift and tire/wheel size correspond, but I'm still learning.
I'm looking at different lift options, and I'm trying to decide which one to go with. I have an 88 EA82 d/r, spfi and I'm looking at mainly doing some "back country" car camping this summer, nothing terribly intense no real wheeling, mostly fire roads/logging roads. I just don't want to bottom out when I have 4 people, a dog and camping gear in the car. I've narrowed it down to the 2" from SJR-This is appealing obviously because it is easy and inexpensive (http://www.sjrlift.com/index.php?option=com_wrapper&Itemid=3) But I'm curious if I would be able to get any larger tire in there, or really gain any thing. For the moment I'm sticking with the stock 13s because I have 2 full sets with tires. The other option is the SJR 4" lift (http://www.sjrlift.com/index.php?option=com_wrapper&Itemid=3) This is also appealing, appears to be fairly straight forward to install etc etc, and I would be able to get 14s or 15s in there I assume. Given my "needs" do ya'll think the 2" lift, and sticking with 13s would work for me? Or would I be better off going with the 4" and then getting bigger tires down the line. Any help/advice is muchly appreciated.
RackBoy
