Selum
Everything posted by Selum
  1. The MY2002 Legacy GT has a limited-slip rear differential. I'm guessing the same applies to MY2003. The GT also has bigger brake rotors than the non-GT model. Best wishes, Myles
  2. These cars have quite a bit of slop in the drive train. If you're used to two-wheel drive cars (particularly FWD), it will take some getting used to. Best wishes, Myles
  3. Did you do the water pump, tensioner, and cam seals along with the belt? Myles
  4. Timing belt change TB Tensioner Water pump Accessory drive belts Coolant change Brake and clutch fluid change Thanks again for the referral. Myles
  5. Hi folks! Haven't posted here in ages. I just moved to Quincy, Massachusetts, and I'm looking for a trustworthy indy mechanic to do a timing belt change on my 2002 Legacy GT (SOHC EJ25). Any recommendations? Thanks! Myles
