Selum
Posts posted by Selum
These cars have quite a bit of slop in the drive train. If you're used to two-wheel drive cars (particularly FWD), it will take some getting used to.
Best wishes,
Myles
You'll get the best service at Chicken and Shakes. It's a total grease shop with no fancy waiting room. If you bring your own parts it might make things to a bit faster. Call them to make an appointment, but they can totally do it. (They did mine.) I stay away from timing belt and water pump jobs simply because it's too easy to screw them up, so when I had mine done I brought it to Chicken and Shakes and they did a great job.
Did you do the water pump, tensioner, and cam seals along with the belt?
Myles
Anything in particular you need? I am a driveway mechanic on-call.
- Timing belt change
- TB Tensioner
- Water pump
- Accessory drive belts
- Coolant change
- Brake and clutch fluid change
Thanks again for the referral.
Myles
Foreign Auto Center in Cambridge. Jimmy is a Subaru expert.
617-876-1262
Chicken and Shakes in Somerville is also excellent.
http://www.yelp.com/biz/chicken-and-shakes-automotive-somerville
Thanks! I'll give them a call.
Myles
Hi folks! Haven't posted here in ages. I just moved to Quincy, Massachusetts, and I'm looking for a trustworthy indy mechanic to do a timing belt change on my 2002 Legacy GT (SOHC EJ25). Any recommendations?
Thanks!
Myles
Shopping the third Generation Legacies: advice sought
Posted
The MY2002 Legacy GT has a limited-slip rear differential. I'm guessing the same applies to MY2003. The GT also has bigger brake rotors than the non-GT model.
Best wishes,
Myles
