Everything posted by Joenasnj
1997 Legacy gt 2.5 rought idle
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeen awhile but finally installed a new coil from the dealer and still have a rough idle and PO304 code. So far the code is only coming up at idle. Any more help would be appreciated. thanks Joe
1997 Legacy gt 2.5 Fuel Gauge Problem
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Just found a couple
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll pick up a new coil tomorrow at the dealer(yes they are cheaper than Auto store) and see if that is it. thanks again Joe
My 1997 Subaru Legacy gt sedan when i run about 100 miles the fuel gauge goes to E. i fill her up and only takes 6 or so gallons. Is this a gauge problem or sending Unit. Being AWD is there one sending unit or 2? thanks Joe
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, I have installed NGK plugs and factory wires and now the problem is worse constant P0302 and P0304. I guessing it must be the coil. I did have the same problem before motor was rebuilt. Any other suggestions. As for the cam adjustment the cams are installed after the heads are installed and i followed the recommendations of my local Subaru dealer. thanks again
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHeads where rebuilt by a machine shop
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going to try the factory wires and nkg plugs this week end and see if that is it. Might pick up a used coil and the bone yard too thanks
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNipper I tied your water test and no problem. I'm getting PO304 code all the time and some times PO302. I spayed carb cleaner around all the gaskets to check for leaks all clear on that. Dickensheets Happens warm and cold xrturbo Yes i did the guy at DMV said the same that i have to drive it for a few to reset those codes. thanks again Joe
Joenasnj replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put new wires,plugs,water pump,timing belt,belts and hose on the rad. Could it be a bad coil? It did it before i did all of the work. thanks Joe
I have a 1997 legacy gt sedan with the 2.5. I have replace the head gasket already. The motor has been running rough before i fixed the head gasket. engine codes of misfire # 4 cylinder and sometimes #2 misfire.Codes have shown up and low and high RPMs. I have put new plug wires and plugs in it. Check the vac lines and they seem ok. Also installed a new pvc valve and cleaned the tubes. It seems to run good at higher speeds. I have also failed inspections due to sensors coming up not ready when DMV hooks up to the the cars computer. Any help on what causes the problem or do i need to take it to the dealer? thanks Joe
