With the bowl vent unhooked, it runs but seems to have a hiccup occasionally, especially at higher speeds.  Throttle response is crisper.
She had started stalling when I stopped in traffic or at lights, so the idle was cranked up a bit.  I was able to turn it down a little, but not to where it should be.  I thought it was due to wear around the throttle shafts, but it could be the anti-dieseling solenoid also.
How does the anti-dieseling solenoid work?  It looks like a spring-loaded plunger and the 12v pulls the plunger into the solenoid and allows fuel to pass?  So resistance of the coil should be low?  And I should be able to test by removing the solenoid from the carb, grounding it and jumpering 12v to the wire?
