crazyeric
Posts posted by crazyeric
So the other day when i was delivering pizzas i got stuck in a parkinglot with probably like 2 feet of hacked up snow so i was beating the crap out of my car trying to get out and by the time i finally did, there was a cloud of nasty smelling smoke which i am thinking is probably clutch because it doesnt smell like tires, anyway. Yesterday im driving on the highway in 4th gear and when i get to about 3500 R's they go up real fast to a little over 4, then catch again. This is the clutch slipping right? WHich probably means that i did infact fry it in that parking lot, Right? The car has about 95k on it and to my knowlege the clutch has not been replaced, i got it at about 74k. One local mechanic who usually isnt into boning his loyal customers quoted 7 or 800 dollars for a clutch. Im going to go to the tranny shop down the street for a different quote but i never go to that guy and im sure he would be less likely to give me a deal. I am not a backyard mechanic, the biggest thing i've probalbly done is an exhaust, should i not even attempt to think about changing my own clutch or is it just drop-n-go after you get the engine jacked up and such. I've heard that clutches on subarus are more expensive to replace because of the AWD. Anyway, if anyone could reply and tell me what i should do and\or what i should expect to pay that would be great, thanks.
sounds like what happened to my 85gl a couple years ago, although i sold mine at that point, it ended up being the carb, check your pcv valve and air cleaner and make sure there's no oil in there. If there is you might have to get the carbs cleaned or rebuilt. hope this helped.
i dont know if this will help but my first sube, an 85 GL FWD 1.8l handled AS WELL in heavy snow as my 99 ouback sport 2.2l, of course the tires on the 85 were probably no more than 7 inches wide so they were able to really dig down, but that car was a beast and i was only able to kill it after a f'ed up the pcv valve and got all kinds of oil in my carb.
you can get another for about $150 off ebay, maybe your discs are in less than perfect condition and the defroster is causing problems with the laser. id say either get a replacement off ebay or if your looking to spend a few hundred, get a real nice double-din stacker with more power, better sound and preamp outputs if you decide to install some subs later.
i was reading about swapping an ej20t into an earlier model such as a 99 outback sport. is it true you need all the diffs and driveshafts as well. Also, id assume you should probably upgrade your brakes and maybe even suspension to handle that extra power. Also, does anyone know where i can find a wiring diagram for an 02 wrx and a 99 outbakc sport? Thanks alot, Eric.
Bump It Up!!!1!1!!!!!!
I've had a CEL on for a couple weeks and went into autozone to get the error codes pulled and they said it was a catalytic converter (bank a i think, the dude said it was probably the front one if there are 2 cats, which there are)
I priced a front cat for a 2.2 non-california emissions front cat at like $650 of the lancaster subaru website. Is there any other place i can get a cat without compromising my life savings? Im sure i can do it myself, i've done plenty of catback exhausts but if i had to pay for the part and the labor it would be a killer.
Hi, i was thinking of putting some foglights on my 99 Outback sport and i wanted a OEM dash switch to occupy one of the blank spaces next to the alarm and cruise control button for a stock look as opposed the red switch that comes with some of the kits. Is there anywhere i can order one of these offline? i havent searched the boneyards yet, but late model subarus are sometimes difficult to come by in these parts. Thanks alot, Eric.
pretty sure it kicks in after 3000 rpms
i ordered a roof-rack from them, and after they sent me the wrong clamps and i called them back they said "sorry, our bad, well send you the right ones" about 4 days later i get an email saying "oh, just send the wrong ones back or else were going to charge you for another set of clamps." i called back and they said that even though the page i ordered from said outback that i should have ordered from Impreza because the outback clamps wont fit my outback sport. I called up and talked to TRISH for about a half hour and they pretty much said it was my problem and that if i didnt want to send them back they would just charge me twice. So, i sent them back... not one of my favorite companies to do business with anymore.
i just got back from the Pomona car show and i saw a guy driving around a little subie van. It said 68 maybe on the for-sale sign but i think he wanted like 10 G's for it. Anyone got one of these little 2 -cyl vans? it looked like a little vw westfalia and was painted all crazy. Anyone else at pomona see this little toy car. There was also a dude driving around an awesome little honda 600cc chopped up go-kart looking thing. He said it had a motorcycle engine in it. bitchin' little rides.
I'd like to buy a new CD player head unit for my 96 GT wagon. Is there a site or thread (I searched and couldn't find anything) that gives detailed instructions on how to do it?
Also, does buying a Panasonic make it any easier with connections (OEM radio is a Panasonic). My car is an auto tranny and has the electric antenna.
Is this an easy project? do I need to do any soldering?
Thanks!
Aja1
go to your local stereo shop and buy a wire harness and faceplate kit you might not need it if the factory radio is the same size as aftermarket. sometimes there is a little storage area underneth the radio in which case you should be able to just screw it into the existing mounting hardware. The wire harness plugs into your factory harness and is color coded so you just connect all the aftermarket wires to the harness and you should be good to go. As for the electric antennae, you shouldnt have any problems, just follow the instructions included with your aftermarket radio. Hope this helped...
My 97 Legacy OB has the same setup as FillG. I found the wires for the button. They are 2 BROWN wires, but don't know where they run. I too don't believe you'll have the same setup.
Sorry
found em! the connector that i broke was hooked up to two brown wires, which i then followed to find that one was cut. after reconnecting them it worked like a charm. Thanks alot! Eric.
i got a spare remote today off ebay, and i went to program it and i couldnt find the programming button under the dash. there was a small push-button which was not recessed in any kind of plastic (and i pushed it for 15 seconds and nothing happened) then theres a toggle switch, then theres a metal nub that doesnt seem to be a switch of any kind which i accidently broke the back off of. The piece i broke had 2 metal contacts that i tried bridging with a key for 15 seconds to see if that would do it, but nothing. looking at my alarm setup, there are abunch of wires which are electrical taped together suggesting to me that something was either replaced or ghetto-rigged. can someone who has the button tell me what color the wires running to it are and if possible send a picture of what the wires and swiches under the dash should look like, i work better with an actual photograph than an illustration in my owner's manual. im not sure if its an alpine system or what but i have a 99 outback impreza sport. so anyone who can point me in the right direction would be greatly appreciated.
dealer quoted $100, napa quoted 80, anyplace i can get this small piece of plasitc for less than 75 bucks?
the other week i got a CEL for the first time in my 99 outback sport, the next day it went off for a week or 2 but the other day it came one and it has been going on and off for the last week or so. I hooked it up to the machine and it said it was a knock sensor. I was reading other posts about knock sensors that said that accelleration and fuel economy was poor because the ECU adjusts the timing to make up for the sensor or something. My acceleration is fine and i've been on the same tank since gas was a buck 80! Im going to bring it to autozone and have them check the error codes just to make sure but can someone tell me how to test the knock sensor, and where exactly it is on the engine. And if it is infact a knock sensor malfunction how to replace it. is there a hayne's manual for 99 outbacks out there someplace? i couldnt find one at autozone. Thanks in advance for your help.
what exactly is "drive by wire"
I was told you can buy that harness from the dealer (parts man at becker in allentown said so)...I have the same thing as you do. (subaru sub from ebay that has 1 end cut off)
Matt
i called the dealer today and they said the harness was not available. did you install your sub with the spliced wire? if so which wires go where?
yes, 120w panasonic subaru from the factory.
I just brought a sub off ebay, it came with the wire harness, but the part that is supposed to plug into the radio is cut off, there is a red wire with a fuseable link, a black, purple, orange, grey and white. I called my dealer AND aaron's but they didnt have it, should i take my chances splicing or does anyone have a fried subwoofer with a harness they are willing to part with? If you know where i can get a wire harness, please let me know. Thanks alot, Eric.
wow, i wish i knew that before i tore my steering collumn up
the only absolutely moronic thing i've done in my sube is once when i was delivering pizzas i was in a huge rush and forgot to put the 85 GL in park and when i got to the door to knock, i turn around just in time to see my beast rolling into the gentleman's garage...oh, that was fun.
99 Outback Sport Clutch
Posted
Bump please
