4byRoo
Posts posted by 4byRoo
Turns out it was a fuel pump kill switch wired into the hazard switch. Weird
Oh well, that's better than it being a huge problem!
90 Loyale Wagon, FI, non-turbo, 5 speed.
Cranks, but won't start. Doesn't seem to crank faster, so I don't think it's the timing belt, but will check it anyways. When turning the car to on, no noise from the fuel pump...is this normal? I'll use a meter to check the voltage, but I was wondering if not hearing it kick on was unusual.
I had a 93 Escort wagon (enduro race car) that had an inertia switch mounted in the cargo area, that once switched, would cut out fuel. If this was switched, the car would crank but not start. This is exactly what the Subaru is doing...but I can't seem to find anything about a similar switch. Was running and driving fine a few days ago, pulled it out of the garage and parked it, went to start it, and it was doing this. I find it hard to believe that the fuel pump just up and quit on me, same with the t-belts, but I've had stranger things happen.
Checked all fuses under dash. None blown. Made SURE I was pushing clutch through the floor. Also checked the plugs and wires, as this same thing happened when I had replaced the dist. cap on my Jeep with a crap no name brand and it was on wrong. Same symptoms - wouldn't start, just crank over and over.
One side note. There is a family living next door with small children (6-8 yrs old) that love to get into my cars. Oddly enough, the fuel door was popped during the time between when I drove it out of the garage and when I tried starting it again. Is there any way they might have put dirt or something into the fuel tank to cause this scenario?
Thanks in advance guys.
Well, this is my daily driver, and probably won't see much offroad, as I have a Jeep dedicated for that. I don't need anything too big, and I also don't want to lose too much power by getting tires too big for the wimpy engine to turn. I just want some better grip in the snow and a wider wheel and tire to handle better. I'm also not finding any pug wheels either.That depends on how much tire you want. Realistically, the tallest tire you can fit is about a 29" tire. THose are available on both 14 and 15-inch wheels, but obviously the 14" wheel will give you more sidewall, something you really can't have too much of when off roading.Just adjust the suspension all the way up and swap in a set of 14" steel wheels from a Peugeot 505 station wagon.
my wagon had a turbo swap done to it last month....pm me or catch me on aim and i'll fill you in on the deatils...oh BTW it's a big frikkin pain in the @ss. i would suggest to buy a turbo wagon:lol:
Forgetting the turbo, thanks guys
Subaru styles, I swear you're the only guy in the world with a subie wagon that looks as good as yours does (not as an offroad vehicle, I mean.) Nice work, seriously.
Anyone on the D/R swap? If it ain't gonna be fast, I may as well look at other things. Oh, and what's the biggest tire/rim combo I can get under the car stock? I'm gonna custom fab a bigger lift next summer, but until then, the stockers gotta go.
If its a MT, it should already have a 5 D/R in it. Did they come with single range that year?
Putting a turbo on it is possible but your looking at alot of work and parts. Its easier to start with a turbo Soob than do the comversion.
Should be a few folks in your area that might have some fenders, Moosens would be one.
It's only a pushbutton single range. And it's definitely a loyale, and those began in '90, if I'm not mistaken, and that's what year this is.
If I get a hold of a turbo wagon for cheap, what would need to be taken, and what's shared? Block/head, tranny, etc? Ignition system? Is it as simple as changing the ECU and intake/exhausts?
Can't seem to find any solid answers, so posting my own. Just bought a 90 loyale 4wd MT wagon. Need to put a new timing belt in. Has 190k on it. Got car for free, so want to see if there's anything I can do to make this more fun to drive.
First, can I put the D/R 4wd in it, and if so, what do I need?
Second, can I put the factory turbo system on it, and if so, what do I need?
Finally, I need a pair of fenders, and a set of wheels and tires. Anyone in the NE area, please email or IM me. Thanks in advance!
bump! help me out guys, its 60 degrees!!
Originally posted by Skip
4by4 since you give no vehicle
I'll take a stab at it being your AMC Eagle??
All seriousness aside
are you aware of the fact that the driver's side window
and only the driverside window is controlled through a control unit?
This is how it accomplishes the power up/down feature.
You may want to try a boneyard model of this unit.
Where it is mounted well in an Eagle it's.....
Hahaha, yeah, me and my Eagle
I have an 89 GL waggy. the driver's side window alone is controlled by a control unit? Where is this control unit, how much would a "new" used one run me, how easy is it to install?
BUmp to the top...got the same problem and we got a heat wave here in MA...I gotta get my window workin!
Here's my deal-tried a whole separate window switch rump roast'y, still no luck. The driver's door window switches don't work for ANY of the windows. The other three doors work fine when their own switch is used. So the chances of it being the motor is slim
I looked in the door jab, played with the wiring going through but there didn't seem to be anything out of the ordinary, and messing with it made no change.
I'm all for wiring a new switch if need be, but this can't be that hard to fix. Please help us
Ok, I have an 89 GL auto PB 4wd, and I want a turbo 5 spd DR
If I buy a turbo wagon 5speed, will I have to swap the engine, or are they the same minus the turbo? I know with my eclipse they were two completely different engines, etc...but wasn't sure how the subees did it. Feel free to rag on me
PS-Anyone in the New England Area want to help me do a 5spd swap? Dinner and beer for your services...
Originally posted by WJM
5spd swap is not hard.
Power mods are easy! Intake exhaust...then...Delta cams. The 677-260 grind should also suit the SPFI engine.
Hrm...intake and exhaust...where can I go 'choppin for those? Ebay is useless.
Cams...I dunno. This is my daily driver, I have enough toys (did I just say that?) The one thing this has to be is reliable...and I dunno if internals is on the list of reliability increasers
Let me know where I can find some cheap bolt ons...homemade is always good too, as this was a cheap car to begin with
Haha, as I'm a member of many boards for many cars...I knew I was gonna get flak for the search function
Thanks man...I'll check that out. I do it every time too...just post away without searching.
It's people like me that waste bandwidth. Look, I'm doing it now, just talking about wasting bandwidth...
lol, I suck!
Aww look, you're a poet and didn't know it! oh!
I'll try locking the driver's door when inside. So they operate on the lever switch....veeeery interesting. I thought they were vaccuum operated, like the old volv-hos.
Lights on for safety!
SO not worth it. That's what I get for not reading before opening my big fat mouth. I'll suffer with the 90 HP wonder and the good gas mileage thank you very much
Though I do want it to at least be a manual. How much is involved in that? Are there different options? Something about a push button 4wd or another option? What are the differences, which is easier, etc?
Ah...I'm home
Guys who know their stuff...and within an hour of my post too!
Thanks first off for responding so quickly and thoroughly.
Now, for the door hinge issue...I'll take a look into it. Since it requires little disassembly, why not, right?
As for the door lock indicator...I dont think I have power locks..there's only four window buttons on the driver's door. I do however have vaccuum locks...turn the driver's key and they all lock. I was trying to figure out if the DOOR LOCK was a reminder, but after locking all the doors, it was still on
That made sense to me, a short was causing it to think it wasn't locked or something. I've seen that before (windshield washer fluid indicator on my Mitsu).
PS-So you guys are saying I can turn my headlights on and just leave them, and when I turn the car off, off go the lights? Cool
I drive with my lights on no matter what time of day. Makes it safer...
Yeah, I'm gonna ignore it...but my curiosity just makes me wonder what the HECK it would POSSIBLY be useful for.
Yeah, thats not a bad idea. I'll hit the JY and see if I can't score a new master switch...maybe just a faulty switch rump roast'y.
Thanks for the input man, anyone else?
So I'm already bitten by the soobie bug...and my 89 GL auto PB 4WD is fun...but not nearly fast nuf
What I'm wondering is how elaborate a swap it would be to swap in the turbo engine and a 5 speed. Or if there's something else that can drop in and make me a bit faster. Anything over 200 HP is fine...this isn't a quarter mile animal, but it'd be nice to hit 65 in less than ten minutes, and tool on some unsuspecting Civics
Cheap is key here-I bought the car with 81000 miles 3 days ago for 300 bucks...so this isn't a 10K project
Thanks guys.
Just bought this 89 GL wagon, and while all the other switches on the other doors work, none of the switches on the driver's work (figures!)
Any idea what might have caused this? Dunno if it's related (if it's not, please help me on this too) but there's a small light that says "DOOR LOCK" illuminated just to the right of the high beam indicator on the instrument cluster.
Everything else seems to work..so let me know if you have any idea why this is happening
Thanks!
PS-That switch on the top of the steering column, apparently for the parking lights...WHAT the heck is the purpose of that other than to kill the battery when I hit it accidentally during the day?
FS: 90 Loyale in MA, lots of new parts!
Posted
Got another project that needs my garage space, attention, and, of course, money
Just bought it a few weeks ago. 192k miles, 5 speed, s/r 4WD, wagon, red/maroon in color, near perfect grey interior, manual windows/locks, roof rack.
Brand new: ignition coil, plugs, wires, cap, rotor, front pads and rotors, battery, axle-back muffler.
Just had rear diff flushed, front was fine.
Passed MA emissions inspection with flying colors.
Failed for rear tires (juuuust barely didn't make it) and an exhaust leak at the driver's side exhaust gasket to the engine. I went through the exhaust from front to back, sanded and painted the pipes, replaced the muffler, all of the gaskets, and replaced three of the four studs that hold the y pipe to the block. One is stripped - it will need to be filled with aluminum and retapped. I've had estimates of anywhere between 50-100. Other than that the exhaust is perfect.
Quirks: It runs a little warm after driving for over 30 minutes on the highway. It has NEVER overheated, just run around 75-80% of the gauge. Turning on the defroster puts it right back to the middle. My guess is a clog in the radiator. Needs a slight alignment, pulls to the left. The dash clock dims erratically. Every once in a while it grinds slightly while going into third or reverse...works perfectly fine though. Can't seem to get the driver's door to lock by key or by the latch inside. Can't get the key in the tailgate lock. Driver's side fender needs to be (or at least should be) replaced; rust has gotten the better of it, but duct tape has given it new life to get through inspection. This also applies to the passenger rear quarter at the rear of the wheel well, though much less severe. Light surface rust around the windshield.
Gotta go soon. Call me on my cell at 617-306-8780 if you're interested or have questions. Thanks!
