BOSS 2" EA82 Lift Kits- $100!!!
Do u still have them. All i need is front.
Thanx loyal 2.7 turbo for the hard work researching springs. Sorry for small pics click on them and they will get big. There is a 1 inch block in front. I cant wait till winter cus bigger tires will go on.
I want to post pictures but cant figure out how to. Thanks to the guy that gave the info on honda springs did it yesterday and want to show the difference it made.
1992 loyale died
That was it thanks u rock.
1992 loyale died
Turns over, timing belt fine, all fuses good. Was driving to work and car just died no spitting or sputtering just dead in the water. Pulled off freeway driving down road went to turn on side street and noticed it was hard to turn looked down and tach was at 0. Let out clutch in second gear and no fire. Puled over to side of road and cranked it over for a few seconds. Towed it home checked the things above now throwing it out there to ya'll.
1992 loyale.
Here is where im at. It has all new exhaust in it u cant here noise outside car only inside. Im going to get to a hoist and check the whole exhaust.
1992 loyale.
I have noticed breaks sticking but that is not this issue. Can the motor mounts be bad and look ok. Should the motor have play in it. I can move motor a bit by grabbing it and moving it but with my hands cant get it to clunk. It has never clunked when starting it. With hood open getting it to clunk i can see motor moving. Im really leaning towards motor mounts. They just look good.
1992 loyale.
I will try tonight but idk how to post a video. To answer question about speed when letting out clutch it happens right before im stopped. Example pulling up to stop sign car is almost stopped clutch is in i see no cars put it in first let clutch out to go "california stop" and it does it. One thing i need to do is replace bushings in shifter in process of locating them maybe that will fix it although it sounds like motor hitting engine bay so i dont think so.
1992 loyale.
I could pull in wet grass get it to spin at low rpms and it will do it everytime. Just did it after checking what u told me to today.
1992 loyale.
I have checked bolts on motor mounts and stabalizer. I live in salem or.
1992 loyale.
No luck was tight.
1992 loyale.
Ok never mind i got u. Will try it and let u know thanks all
vedder37
