murphsubaru
Posts posted by murphsubaru
I own a 99' Forester with 190,000 miles. I am trying to decide if it is time to sell. It needs an exhaust system, new tires before next winter, regenerative gas fume system repaired before E-check in March, it is burning oil (2 quarts per 7000 miles), leaks transmission fluid, and cv joints are clicking in sharp turns. It only has a few rust spots. Interior and exterior are fine. It runs fine. Any thoughts?
My 99 Forester continues to warp front rotars. I thought I corrected this problem with the last brake change by replacing the front pads, rotors, caliper pins and carage barackets. A few months later one of them is warped. Any suggestions.
I am not sure it's worth spending $500.00 on a timing belt change on a car with high mileage and rust. Maybe I should wait until the belt has 105,000 miles.
How long do the replacement timing belts last on a 99 Subaru forester. I had mine replaced by the dealer at 90,000 and now have 177,000. Do I need to replace belt at 180,000? Do the replacement belts last longer than the original belt?
Thanks
What is a zurk fitting??
Power steering pump is not leaking, ball joints have been replaced. I oiled the u-joints coming out of the firewall but not near the rack. I'll try that next. Thanks for all the suggestions.
It's an automatic, yes tires pressure is correct, belt fine, fluid changed with rack and pinion replacement. Sometimes on the freeway steering feels like it is tight or stuck. This problem started about a month before the rack started leaking. I had to occasionally add fluid.
I just replaced the rack and pinion on my 99 Forester with 169,000 miles. It was replaced because it was leaking. Before the replacement, occasionally the steering felt stiff especially around curves and corners. The problem remains, is my pump failing????
Is it possible to patch a tiny leak on a power steering pipe? I have a 99 Forester that's leaking at a corroded elbow.
My 99 Forester at times experiences stiff steering. What are the signs of a failing power steering pump and or failing rack and pinion ?? Tie rods have been replaced. Car has 167,000 miles.
My 99 Forester with 167,000 miles is making an odd knocking sound from somewhere in the engine. I only hear it at idol with my head under the hood. Could this be the waterpump bearing failing? It was replaced with the timing belt at 90,000 miles. This sound a lot like the sound my 1980 dodge cold water pump made when it was failing.
Where can I purchase a used keyless entry remote for my 99 Forester? New one on line is $57.00
My 99 Forester check engine light code is p0440. Anybody know what this means, and how do i fix problem. Thanks
What year and model/engine?
The EJ22 stock plug should be replaced, but the EJ25's platinum should be OK to 60K, which is good since they are a PITA to replace.
The wires should be replaced if sparking. I'd double-check how they're routed to ensure they're not in harm's way.
Td
99 forester 2.5
where the wire bends.
Is it likely that I would need to replace plugs or wires after 50,000 miles? The car runs rough when first started after it rains. I spritzed the wires with water and saw some minute sparks in a few spots. This car has 153.000 miles. The wires are subaru wires. I did not see any arching on the distributor.
My 99 Forester is showing code: PO440. This is a vacume leak. Any suggestions what I should check first? What usually causes this?? How do you check a gas cap?
No, had it checked at AUTOZON, he didn't give me the code.
My 99 Forester's check engine light is coding there is a vacume problem somewhere. I oiled the gasget around the gas cap but light came on again after being reset. Any ideas what I should check????
There is no specific fuse for fuel pump, and I cannot find any wires infront of the rear right wheel to disconnect fuel pump. I see a wire coming through body pan and into tank. Is there a fuel pump disconnect on a 99 Forester?
could i pull the fuse instead??
How do you release the fuel system pressure before replacing the filter???
I have a 99 Forester.
Anyone know how to remove the washer pump from the reservoir? The pump for the rear window is not working on my 99 Forester.
Keep it or Sell it!
Posted
The emission code is 440-evaporative gas fumes system.
Exhaust is breaking at a flange behind converter. I won't by another Subaru, this has been the most unreliable car I have ever owned.
