soccer13wv
Everything posted by soccer13wv
I installed a 2003 Legacy L transmission into my 97, I should have pointed that out previously, my apologizes.
A separate question. Once I installed the newer transmission, i feel like the revs are considerably higher then before. Is there any reason for this?
Thanks for all the help.
Rick
I am not overly familar with everything. i just did my first engine and transmission swap in the last month. So still got a lot of learning to do. I just need to understand what exactly I need to look for in the shifter linkage. That is also assuming that I understand the linkage to be the u shaped piece of metal connected to the shifter near the bottom and exiting the bottom shifter boot at an angle towards the front of the vehicle. Thanks for the help a head of time.
Rick
Hey I am a friend of Gary Gross's and he said you might be able to answer a question about a 5mt problem I have. I just installed a used 5mt into my legacy and it is slipping out of 4th gear after shifting from 3rd. Once I try again it will stay in 4th it seems. I assume this is a the start of a synchro problem. Do you think switching to red line gear oil will fix this problem? Also, is it possible that when I re-installed the clutch cable that it's too tight/not tight enough and causing this problem?
Thanks,
Rick
