drew440
Posts posted by drew440
if you give it more gas and it doesn't do it, do a voltage sweep on the TPS. look for spikes or dips.
I will check that this weekend. Thanks.
Had the tires checked and the alignment checked as well. The CV joints are in like new condition along with the struts. It definitely appears to feel like a mechanical or drive train deal. The thing feels like its shaking apart along with the feeling that the drive train is faltering. Could torque converter give that kind of impression?
What would cause the car to shutter at precisely 35 mph? The car just turned 38, 000 miles. It does stutter or bog a bit when cold when first starting out in the morning, but do not notice it at any other time. The shuttering can be felt through the gas pedal, like it is either the automatic transmission or possibly a fuel starvation issue or? I am not a mechanic and do not play one on TV so any advice would be greatly appreciated. Thanks.
I use 15w40 Shell Rotella. It seems to do well and I change oil every 3k. I run that oil in everything and have not had any issues. I agree with the keep it clean theory. I had a diesel rabbit that I ran Mobil 1 in and changed it every 3K along with the fuel filter and air filter. It had 31K on it when I got it and it had 131K when I sold it. Never an issue but it was overkill. At that time I also bought in to the theory that if it costs more, then it should be better. I have a serious drag car with 957HP (Dyno) and it burns E85. I run 15w40 Shell Rotella in it. It has around 25 passes on the engine. I've changed oil in that engine 5 times (9 quarts) and have looked everything over to find no wear issues. If you keep the oil from breaking down, I think you could use any quality oil and be fine. Just my 2 cents worth.
I was skeptical about these cars at first but i have 200k on mine and it still works good. The typical thing about these cars is that they get eaten up buy rust pretty good. Keep that in check and keep up on the maintence and you should be fine. These are great cars and the 4wd system is better then the yotas only because you have the dual range option if your so equiped. Even if you have single range its great in the snow and mud.
Mine is only 2 wd in the front, and it handled great in the snow. Only thing I don't really like is that it is a 3 speed and has no real overdrive and the fact it really doesn't like 87 octane gas so I use premium fuel and it seems not to ping using it but the cost is greater. Other than that it functions properly. The guy I got it from said that the a/c works fine but it will shut off and you have to turn it back on intermitenly. What do you think that could be? Thanks.
Glad you got this worked out. Now you can say to your friends whose laughing now.
You would not believe how much crap I had to eat over this one. I sold my 1991 toyota corolla all-trac wagon with 52,000 original miles and kept this subaru as we are down-sizing the vehicle situation around my place. That car was perfect as well. I always heard that subaru was a good car and it was in near new condition with only 28,000 miles so I took the leap and kept it. I hope to have many miles and good memories with this one. I really appreciate this website and all of its members for helping me with this situation as I have gotten to know the vehicle better. I have been offered more than I paid for it several times, but I hate to get rid of it as I really don't know what I would get to replace it. Thanks again for all of your help!
I am back home now and have access to my service data. Here is what it shows. Fuse 11 provides power to the coil and fuel pump relay (I think that was mentioned already). So with the ignition OFF you should have good continuity between fuse 11 and the plus side of the coil but that isn't happening apparently . It has already been dertermined that fuse 11 has power on it and is a good fuse. The b/w power wire from fuse 11 goes through a couple of connections before it gets to those locations. One connector is called F66 according to my '88 manual. The other connector is F98. If these connectors are the same for your model year then they are located up in the far corner of the dash on the firewall, near the driver's door jamb. There are 4 connectors in a line. The second on the left is F66 and the fourth is F98. By just pulling the connectors apart and reconnecting them you might solve this trouble.
I think I have it! I was under the dash and saw these two clear plastic conectors that looked like they belonged together and plugged them together and whala it fired right up! I have absoltely no idea how they came apart. What are these connectors called? They are kinda long or wide and clear or opaque. I really appreciate everybodies help! I hope this fixes the problem!
I'll try it! Thanks.
That is the lockout to prevent shifting into gear without a foot on the brake. And also to not let the key come out until the the shifter is in park.
HOWEVER.........I didn't think Loyales had that feature.
Are you sure we aren't talking about a LEGACY here?
It is a 1993 Subaru Loyale 1.8, automatic, with a/c, power windows and locks, tilt wheel, rear window defogger and clock. Pretty nice car with 28,000 on the odometer. That is why I purchased the car because of its condition and miles. Not one spec of rust anywhere underneath or on top. Interior is perfect as well. It was as close to a (new) used car as I could find for the money.
Okay, new idea.
So I have been looking over this again and again.
Power for the Ignition relay, and one of the ECU pins comes straight from fuse 12.
Now, the wire splits, and the side that goes to the Ignition relay has a diode in it to prevent voltage *backflow* to the ECU.
It is possible this diode is not conducting anymore. It is taped to the wiring harness, up under the dash, in the same area as the ignition, fuel, and headlamp relays. If you have Section 6 of an SPFI FSM, it shows as connector F109 on the connector location chart.
I'd pull that sucker and see if you get voltage through it. Test it's *oneway* function using the diode check on you're multimeter.
I'll do it. I noticed that when the key is in the on position I can push in the button on the auto shifter and it clicks at the ignition cylinder where the key goes in. Is this normal? And the shifter will not move unless I push in the shift over-ride button. Could this be a neutral safety switch problem?
Not as far as power to the coil is concerned.I would sort this issue first.
If you have power on both sides of the fuses,there must be a break in the wiring between fuse 11 and the coil.Could use the ohmmeter to confirm lack of continuity between here and the coil.Problem likely lies at either the 3? or 7? pin wire connectors in between.ECU power loss is likely at the same location.
One of the black/white wires carries power to the coil from the fusebox.
I'll start checking that in the morning, thanks.
Hmmm...If you have power at 11 and 12,the switch and link work.If the fuse is good, you should have power on the coil.
I know. It is just totally crazy. Do you think it could be a ground?
You need to make sure that the suggested electrical areas are getting voltage to them using at least a test light probe to verify the voltage.
I checked them with a volt meter. I have 13.48 volts at the fusible link and 13.44 at fusees 11 and 12. I replaced the ignition relay and I have power going to it. I will check, recheck power at the ignition switch. I guess I'll try and find some more grounds to check. Thanks.
I checked the link and it is fine. Can anyone tell me if anybody in my area can help with this? I'm in Muncie. IN.
The actual link is black,it feeds a white wire in the harness.
I'll double check that link. thanks.
This is getting slightly silly.Bad grounds,coil,ignition reley and ECU won`t prevent the coil from powering up.
What could it be? I really need this car in service!
I was just reading back in the thred
1. the clock.. its easy to fix with a soldering iron. open it up and wiggle the wires, you should be able to see a broken solder joint
2. if you strip a rotor screw you can take a screw from the little metal plate (dust shield) just below the rotor. there exactally the same size and pitch, tha plate wont go anywere with one less screw. if you need pics let me know
I will keep checking grounds and anything else I can find. Just tried the used ECU and that did not work. Back to the drawing board. I will try to post pics soon. Any more ideas on what to check? Thanks.
No power at the coil? That makes it easier.
If fuses 11&12 are both good,it has to be the white fusible link,ignition switch or wiring.
Best way to check link and switch is to check for power on either side of the fuses.(11,12,key on)White link supplies power to both w/key on.
Coil will power up w/o the ECU,just won`t ground and spark.
Check fuses by ensuring power on both sides.
You are getting close.
I do not have a white wire in the fusible link area located in the engine area. I replaced the ignition relay and the coil. I am going to go and get a used ECU today so I can rule out the ECU. I hope this will work. Thanks.
I am out of time for this day. I will test that relay in the morning. Thanks again Gloyale and all others for your help. I cannot think of having this car out of service any longer as I am taking quite a lot of you no what from my toyota pals over this. They are relentless in geers and jabbing fun at my little falty car. It is quite sad to be honest. Of course all they can say is that I should have kept my All-Trac Corolla Wagon and I would be driving it instead of working on it. I'll let you guys know what I find out in the morning. Thanks again.
The ECU grounds the Fuel pump relay to complete the Fuel Pump and ignition coil circuits.
If the ECU isn't getting power, neither will the Fuel Pump or the Coil.
Test the relay OK?
Ok. It is the brown looking small box on top of the steering wheel bracket correct? And thank you very much for all of your insight on this deal.
Okay. So pull out that little brown relay.
Hold the relay in you're hand, and turn on the key. You should feel a click.
Then check for power on the Red/blue wire and the White wires. Should be 12v with key on.
IF not, replace relay.
Is this relay a dealer item as I have contacted the parts store and they do not list one for this model?
FSM lists fuse 12
Fuse 11 is for Fuel pump relay and ignition coil. Not part of ECU power.
Now if he had no Fuel, he would check that. But he has no power to the ECU.
Come to think of it I do not hear the fuel pump when I turn the key to the on position. Is it already primed as I have tried to start it several times? I did the little test with putting a little fuel in the throttle body and then trying to fire the engine. I then moved to the spark tester and concluded that there was no spark. I am not getting any power to the coil period. I did the ohm test and it is within spec according to the manual. What is this amplifier (transistor) thing mounted to the bracket below the coil. I didn't get any juice at this thing either. I keep trying to eliminate things and I'm still in the tracking mode. To tell you honestly the car is like brand new! It is originally from Florida and now is in Indiana. I tried to locate all of the grounds and took them apart and sprayed PB Blaster on them for added insurance, but they all looked perfect as well.
It also supplies *all the time* power to the ECU.
Does you're horn work? Flashers? you need to make sure that cicuit is getting good power.
The fact that you're CEL isn't lighting at all means you have no power on that circuit to the ECU
I went to every fuse in the block and made sure the voltage was perfect. I even took every fuse out and replaced them with new ones even though they were perfect. I took all of the fusible links out one at a time and inspected them and they were perfect as well. Horn and flashers work perfectly. How do I test the ECU? Could it just go bad? I'm beginning to look in that direction as everything else I've tried to test is perfect. Could someone tell me what is up with the little screw in the rotor button! Who the heck designed that little jewel! A complete blind set up in that! I ended up stripping the screw trying to put it back in and when I called the parts store they said the new rotor doesn't come with a new little screw! I guess I need to walk away from this for a little while and do some brain storming on what could be the cause of this malfunction on an otherwise perfect little car.
SPFI right?
In no paticular order:
Fusible links,ignition switch,fuses 5&11,IG relay,wiring,and ECU for the sake of completeness.
Probably fuses or links.
Yes it is the TBI or throttle body type fuel system. I thank you. I will concentrate my efforts on these systems.
shuttering at 35 mph in loyale?
Posted
I did that test and could not get it to make the vibration. I will go back to the tire store on Saturday and have them double check the balance of the tires. Thanks.
