So the other day my friend calls me up and starts talking about how her Subaru is doing something really odd and that she THINKS she can make it to Portland from Eugene. So my first thought is, wow, this must be pretty messed up. She makes it to Portland and takes me on a test drive...
We head to Vancouver from my place (10-15 minute drive on the freeway) and nothing happens. Im on the edge of my seat, mainly just waiting for noting to happen so i can call her a retard. Well, i was wrong. In this order...
-Headlights start dimming and then going back to full brightness and then pretty much go out.
-ABS light comes on
-Speedo & tach peg to zero
-Battery light comes on
-check engine light comes on same time
The car keeps running, but i guess, if you were to use anything electric, such as a turn signal, the car would die mid roll. Even when we pulled to a stop it died just because the idle was horrid.
Now(while still driving), She could press the clutch back in and then let it back out and when it grabbed the gauges would shoot back up to where they needed to be. Then, after a moment or two, go through the whole process again fairly quickly depending on how long you left the clutch in for. She did this a quarter of the way home from Eugene. =[
Now, if she lets it run until it dies, the car wont start again because the battery is drained, so it needed to be jumped.
If you let the car sit in neutral for like 20 minutes it charges the battery enough to let make a run for about 15 minutes.
Here is the kicker, it it stays under 2K it lasts way longer than above. Running it at 3K makes the problem kick in way faster.
She had replaced the battery...a week ago i want to say and it killed itself over the span of 3 days. Ive had the car at my place for 2 days and started it every morning. I just checked it right now and it had a slightly slow crank(for all i know its normal for it) but fired up almost instantly.
I really dont think its a short anymore, but after a little reading it seems that MAF sensors are a huge problem on these cars and then the alternator seems like a problem, even though she said she had it tested at 3 different places and it checked out clean. Thoughts?
