ea81 axle eater
So it turns out that the place that was supposed to order motor mounts for me found out they couldnt get them but never called me to tell me that so now a week later im on the search for motor mounts again. Any one have any motor mounts they want to sell? That would fit an 85 brat with an ea81.
ea81 axle eater
Thanks for the help! went out today crawled around for a short time pushed and pulled on the motor and found the drivers side engine and trans mounts to be T/U. So I ordered some new ones from a local parts guy today hopefully theyll arrive and I can install tomorrow.
ea81 axle eater
I made a heat shroud for the exhuast and it didn't seem to make a differance. But the camber in the front does seem to be toed in a bit. I'm not sure about the crossmember but I think it does have blocks. The guy who I bought it from said the lift was built by superior subaru in seattle so I would think that the lift was done correctly but who knows.
ea81 axle eater
I bought a brat about 4months ago allready lifted ( 3inch) with a set of 14'' pugs. The only problem is that it eats the passenger side inner doj axle boot then axle faster than I can deal with does any one have any advice on what might be causing it or how to keep it from going bad? I've put three axles in and cleaned and rebooted one in the 4 to 5 months I've had it. Thanks in advance for any help.
Tires?
I would like to get some 14 inch wheels but dont know who makes 14s that fit the sub lug pattern. any ideas?
Tires?
I am about to get some new tires for my subi and was wondering if any one had any good suggestions for a good off roading tire that will fit on stock sub rims my budget is about 45 a tire. My car is a '82 gl wagon dr 4x4; also planning on doing a 2 or 3'' lift. Thanks
suspension ride hieght adjust?
Thanks for the feed back
Another 2" lift done!!!!!!
Hey I just got a 82 gl wagon 4wd and was wondering how much you thought it would cost me in parts to do a 2'' or 3'' lift and what I would need? thanx
So I just bought a 82 gl wagon 4speed manual dual range 4wd and read in a book that you can adjust the ride height by turning some nuts. Just wondering how much I can adjust the height and if its worth doing or will it just F*** a bunch of other stuff up?
'82 Gl Daily
