lazerfloyd
  1. Funny, I just logged in here to find out the answer to the same question. We're probably looking at the same craigslist ad. The car I would be looking to swap into is a '95 Legacy L, but I'm guessing the same difficulties would apply to my car too. I'm too cheap to buy a WRX (and pay insurance on it), but fitting a used turbo motor into my Legacy and not telling anyone about it.... someday. Note also, that ad is a re-post from about a month ago... it still hasn't sold.
  2. OK I think my original post was a little confusing as to what I was hoping to get out of this. I wanted it to be less of a “are my mechanics right/what is wrong with my car” post, and more of “will these transmissions from other years/models fit my car” post, which is why I put it in the “retrofitting” part of the forum. I drove the car in question a little bit the other day, and am now absolutely positive this transmission is totally f’ed up, and I need a new one. I will have the shop check out the mounts and correct as necessary when the work is being done. Basically what I wanted to confirm was, will a 5spd manual transmission from the years/models I listed be a direct, no-modifications-necessary swap into my 2000 Outback. The models I have listed are there because (as I understand it from my reading): • There were few if any changes made to the chassis dimensions/mounts of models from 2000 – 2004 • The final drive ratios are the same as mine (4.111) based upon that chart I linked to I am looking for feedback from anyone who has done a transmission swap between some of these models I have listed and can verify I’m on the right track. I do not know the source of that gear ratio chart, and do not want to just trust something I found on the internet, buy a salvage transmission from some place across the country, only to have the guy at the transmission shop tell me it won’t work, and be stuck with a transmission I can’t use. Thanks, Matt
  3. Just the driver's door controls the other locks. EDIT: Sorry 2.5GL! I didn't realize you answered this, and I don't know how to delete my post!
  4. Hmmm, that is an interesting situation on your car. On mine, the locking/unlocking seems more random. Hitting a bump or slamming something inside doesn't necessarily set it off. I have had the car parked for a few days out in the driveway, and was doing stuff in the yard nearby, not touching it, not doing anything at all to the car, hadn't done anything to the car for days, and I could hear the locks randomly locking/unlocking. I haven't gotten the chance to look into my problem yet. Busy hectic week. Hopefully I get to it this weekend, after I address my wife's SUS knock sensor issue. Also have big transmission problems with my Outback that I'm going to start another post about soon. I love these cars, for the most part they've been trouble-free for me, but man, when it rains, it pours.
  5. Thanks for all the replies. I'll check into these things and clean the contacts, and report findings. -Matt
  6. When the driver’s door is unlocked, the remaining door locks on my 1995 Legacy sedan (the passenger and 2 rear doors) will lock/unlock at random. Nothing really seems to set it off, it does it when I’m driving, when stopped, even when it’s just been sitting in the driveway, parked for days. Fortunately, when I lock the driver’s door, the other doors also lock, and as far as I can tell, will not unlock randomly. So security for my parked car has not been an issue. But I don’t feel secure with this anymore. Is there some sort of “main control unit” for the door locks that is responsible for sending the signal to the actuators to lock/unlock? I’m thinking something like this is at fault. Where is it located? EDIT: There is no keyless system on this vehicle, so rule that out.
  7. Thanks for the reply. I recently changed the transmission oil in the vehicle with 75w90. Before I changed it, the level was reading high (I bought it this way, used with 145k miles). I refilled with the proper amount and it stays steady. I was thinking the mounts could be the problem, for the same reasons you described, but when I asked various mechanics (and suggested to them that maybe it was just the mounts) they all sort of dismissed that and said it was the synchros. These are guys whose feedback I would trust, although I was a little skeptical... Anyway, I think by this point I have done some damage to the tranny too. Edit: Before I had the shifting/popping out of gear problems, I had the exact same symptoms as Wondercow2 in this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=69796&highlight=transmission+tranny+mounts In the thread, it doesn't seem like there was a resolution. I'm going to search around this site for info/tricks on how to freshen up the mounts... if it can be done without disconnecting anything (axles...) maybe I could try it myself. Engine mounts seem OK to me...? when I start/stop/rev the engine it stays pretty still.
  8. Hi all, first post on this forum for me. First, some background on my problem, to make sure I understand the problem and am taking the best approach to fix it. The 5-spd manual transmission on my 2000 Subaru Outback AWD Wagon is on its way out… it grinds occasionally when shifting into 3rd, and it pops out of 4th almost all of the time. It used to just pop out when “cruising” (i.e. steady throttle at a sort of balance point between accelerating and engine braking), now it does it under acceleration and even when just when I let out the clutch, accompanied by much grinding. Also, in general, it feels like there’s a lot of “play” in the drivetrain, that is, step on and off the accelerator and there is a fairly harsh bucking, and the shifter seems to move front and back a lot when stepping on/off the gas pedal. I have described this to a few mechanics I know, and they all said it was a problem with the synchro gears, and maybe some other transmission internals, and that the most cost-effective thing to do would be to find a decent used transmission and swap it out. I have called a few transmission shops and used transmission salvage places, and no one can locate one. I’m wondering if these places are familiar with the interchangeability of manual transmissions from different years/models? Based on this chart... http://www.northursalia.com/techdocs/trannychart/trannychart.pdf … and other things I’ve read on this forum, I’m guessing I could also use a manual transmission from a US model: 1999 – 2004 Impreza 2.5 RS 2000 – 2004 Forester 2000 – 2004 Legacy GT 2003 – 2004 Legacy L 2003 – 2004 Legacy Outback 2003 – 2004 Baja All of these apparently have the same 4.111 final drive ratio and push clutch as my 2000 Outback, which is the important thing right? I don’t care about differences in the 1st – 5th gear ratios, in fact, I would like a taller 5th gear. Finally, I need to make sure these will fit right in with no modifications to mounts/cradles/shift linkage/axles/etc, since I’m having a shop do the work. Can anyone verify that any/all of the above will work? If I buy one that won’t work, or isn’t a direct fit, I’m stuck with it. Also, any leads on a reputable salvage operation with a decent Subaru inventory to find a used transmission? Thanks for any/all input and advice. -Matt
