mountaincarpenter
  1. My 88 GL Wagon has radio memory with a green wire (battery +). There are 3 separate positive lines to service the radio. Ground (-) Black Memory (+12v Constant) Green Ignition (+12v Switched) Blue/Yellow Illumination (+12v Switched)Red Mystery wire Red/Green Illumination ground??
  2. You could get some PUG rims. They have a 1" greater offset....
  3. What's the difference between an oil cooler and an intercooler??
  4. Does anybody know what is different about a 'generation 3' head for an ea82 than earlier generations? What does 'generation' refer to anyway, with regards to these engines? Is the generation 3 head off an ea82 or some later engine?I seem to have gotten off this message board or the byb board hints that this is an improved head with regards to turbo engine over heating or blown head gaskets which the turbo seems notorious for.
  5. It's not an xt, I don't think. What's an xt? It's in a regular 88 gl10.
  6. How much do 'King Springs' heavy duty 'standard height' springs raise the rear and front of a gl wagon?? Is the front camber still adjustable to spec.'s? Are there any other aftermarket springs available from a U.S. manufacturer?
  7. I'm looking for details on how to install an (wrx) intercooler . Also, is it possible to use an existing AC radiator?? :-\
