BrokenSubaru
Posts posted by BrokenSubaru
  1. OK, I'm trying to track down my P0442 code problem. I've read all of the posts. I previously had a mechanic replace the purge solenoid. I pull the inner fender wall to take a look at the fuller tube and it looks pretty rusty. I tried to follow it, an it seems to go way into the abyss :mad: above the rear suspension. So where is the vent solenoid, and is changing the filler tube on a 2001 Legacy a nightmare?
  2. I re-charged the system and the a/c is working fine. What is weird is the system had a static pressure of 60 psi before I evacuated it? The compressor was coming on and no cooling. The manifold gauges were showing 25/100 psi low/high readings. Prior to the a/c going out I had a bad radiator and a couple of overheating episodes. I figured I would evacuate the system to ensure that I added the right amount of r134a gas.
  3. OK, I evacuated the system a brought the system down to -30Kpa. After I closed the valves and turned off the vacuum the system slowly went down to -22Kpa after an hour and is holding at that pressure.
    One of the other posts mentioned that this might indicate that the dryer should be replaced?
    This looks like the dryer with pressure switch on top. What kind of connector is that, and do I need some kind of gasket stuff?
