			legacysubaru
				Posts32
Everything posted by legacysubaru
	Just got back after driving forever to find a oil pump O-ring. Yes I did put it back to the left w/ flat head. I'm sure the timing is dead on. I did find the culprit. A piece of RTV gasket in the rocker arm shaft oil feed line. Now I'm going to bleed the HLA's in oil and get the air out. I did not buy new o-rings for the HLAs. THey were ungodly expensive. IS there any advice out there on when doing this bleeding? If there is more debris in the cylinder head passage way is it best to blow into the the cylinder head and with what type of cleaner should I use? Would brake cleaner be ok? I was planning on changing the oil right afterward.
	Gary, I'm pretty sure the tensioners etc.. are ok. the noise actually appeared suddendly Tuesday morning after about 5 minutes of driving. THe noise does sound like it is coming from the right side of the motor and that is the side with the lash. ( i could move them with my hands). ALso, I used the wrong type of sealer on the oil pump. I used a non anaerobic type of ATV. A piece may have come off and obstructed the passages.
	I have only pulled off the right and left covers to check the sprockets for looseness and there was none. I do remember triple checking the idlers and tensioner for tightness. It was the sprockets I was unsure of. Well, I did pull the valve covers off. Plenty of oil in the cover and rocker area, althouhg there was a bit more on the left bank.( noise is coming from the right bank) One think I noticed was a good amount of slop ( you could move the rockers with your hand) in the right bank. This was in the valve closed position. In contrast the left bank did not have any slop whatsoever. I tried this in different rotations of the engine. Is there supposed to be any slop in the rockers? I would not think so. And if not what is the next step to alleviate this problem. Thanks.
	Ok, so it is not a loose cam sprocket for sure. The noise is coming from the passenger side rocker "area". Is there a chance the adjuster came loose on a rocker? (forgive me I know very little about these engines and I know they are not called rockers in this app but I can't remember the right term) It almost sounds like a loose rocker arm. And what would the sound difference be between a loose rocker and a oil passage block causing oil starvation?
	Idler's are brand new as is the idler tensioner. I did reuse the Tensioner because it was within spec. I'll do the screwdriver thing tonight. I'm sorry, what are HLA'S? I did tighten up the backplate screws on the oil pump along with a new o-ring. I'm wondering if one of the cam sprockets has come loose and is making noise. I had a hard time getting one of them tight.
	This morning I decided to head to work early. THe car started out fine. I was driving all was good then all of the SUDDEN the engine, when taking off from a stoop light it started clacking pretty bad increasing as the rpms go up. so I Pulled over checked the oil, it was fine. The car is running fine. No misfire. Drives fine its just loud clacking. To my ears it sounds valve train related, not so much a deep knock, but I don't know subarus that well. Car is a 2.2 1995 Legacy. I just replaced the timing belt, cam and crank seals. I drove it about 100 miles since without a flaw till about 20 minutes ago. Could something have come loose? Like an idler? But it sounds more internal and repetative like. Could the valve lash have mysteriously just went out all of the sudden while driving?? Any suggestions?? :eek:
	Thanks for the good word. The left bank camshaft has an o-ring inside where it bolts to the head. I noticed some around the outside of the area. Probably from the valve cover gasket. Should I replace that o ring?. I really should have got the kit. Now that I have it apart. I have noticed the idlers and idler tensioner are far from new and should be replaced. The previous mechanic 20k miles ago did not replace them ( just the belt). ANd what do you mean by the "baffle plate leak"? The valve cover gaskets??
	Yeah I guess I could do the cam seals at the next interval. It's at 80k now so that would put the next t-belt replacement at 140k. Are these cam seals good for 140k? I'm sure they are the originals. Would hate to see them start leaking at like 100k. And how much harder are these cam seals to replace than the crank seal? Also, I plan on just changing the belt but still using the old idlers and tensioner. The reason being the belt was changed at 60k so I figure they should be good. I'll go ahead and check the tensioner's resistance and make sure it's within spec.
	So just to fill everyone in on whats going on a 1995 2.2 legacy I purchased not long ago.... and I have questions... I have an oil leak that seems to be coming from the crank seal. Oil is burning on the exhaust. From the below you can see oil on the t-stat housing, oil pan, bottom of t-belt cover. I have the cover off and you can see some oil inside the bottom lip of the center cover piece. Also, some traces of oil on the front of the oil pump. Before jumping off the deep end let me get a things straight. I read that an old pcv can cause access pressure and make seals leak. WIth that in mind, should I stop what I'm doing put it back together and just replace the pcv valve? Or is that just a band aid on damage thats already done and may not stop the leak but just lessen it?? Also, the cam seals do not seem to be leaking at all. Should I leave them alone or go ahead and replace them as preventative maintenance. THe car is at 80,xxx miles. One last thing: When pulling the crank and cam seals is it possible to do it with a flat head or somthing like that? On my Mercedes I was able to use conventional tools when pulling the crank seal and had no problem. But I keep reading about using a special tool when doing this job on a SUbaru> Thanks and Happy holidays.
	Can you email me you "nose job" on a 2.2 liter engine. I'm in the process right now and could use all the info possible. Thanks!
	After replacing the front passenger cv joint there is a slight shuddering mainly in 2nd gear (a little in 1st) under load and under 3000 rpm's upon acceleration I goes away after 3000 rpms and does not do it in higher gears. Alignment seems good, no pulling, no engine misfire, wheel vibration etc... The car is otherwise smooth but for just that small section in the rev range and in that gear. What gives? Could it be a worn motor mount? Could replacing the cv axle tightened things up thus showing other weaknesses? What should I be looking for? By the way the driver's side was replaced fairly recently before I bought the car.
