ThosL
4
Posts posted by ThosL
This is an excellent video on a later Impreza, probably roughly the same parts:
This is probably beyond my ability, a 2002 wheel bearing replacement due to the tools required on an old car. A friend is mechanically adept, has a lot of Snap on tools.
I was checking Amazon, and it looks like replacing the whole hub is the way to go especially since I have only 4/5 studs in the hub and replacing the hub would address that. Is it likely that missing one stud damaged the bearing?
Also the rear main seal is leaking, are there any stop gap measures on that? To fix it would require engine removal.
Thanks as usual for the help.
I was able to get around $300 for my last junker, I'd think metal prices are up.
I'm thinking that after the pandemic there are a lot of people in rough shape, families that have lost people and some opportunities like this as well as predatory buyers. Let's hope most people know how to get top dollar for their cars.
- 1
I'd think with how little junkyards have been paying for vehicles you selll to them that they would be set up for that.
The last ones I junked were around $250 in the fall of 2021 when prices were up, they towed it. The one before that in 2018 where I was paid around $80. They just do not give any financial incentive to the extent that a neighbor who had to get rid of a Forester because of parking issues, all it needed was a starter AFAIK, was also paid under $100.
Some curved balls on this job which I did not anticipate checked out some Youtube videos. One was the difficulty of accessing the bolt on the valve cover lower one toward back on driver's side. Also after putting the driver's side back together was getting oil burning smoke, so I took it all apart again thinking that the valve cover was not evenly snug. After that no real problems after running it a while.
2 hours ago, el_freddo said:
What model Subaru are we talking?
I don’t know how much that imperial liquid quantity is in metric terms, but it’s normal for some oil to come out when you remove a cam cover.
Having the vehicle situated with the cam cover facing up an incline will help reduce this oil loss.
Cheers
Bennie
2002 Forester. It was old oil, I changed it out last week so it must have been in there sitting.
I changed my oil last week and started in on my valve cover gasket replacement today. When the bolts loosened as I was removing the cover, some old oil leaked out probably 8-10 oz or more. Not sure what that means; possibly a previous overfilling where extra oil was pushed up in there? The outside of the plug wires previously had a lot of oil on them, why I decided to change the valve covers, etc.. I don't know how this would have happened. Also there was some milky residue on the inside of the cover though I don't have any head gasket issues.
Going with Denso Platinum plugs, I assume these are as good as the NGKs? https://www.amazon.com/dp/B08PVYN3N4?psc=1&ref=ppx_yo2ov_dt_b_product_details
There's a mechanic who has a lot of followers on Youtube who reviews many of the fluid additives and makes a lot of sense. Greyhaired energetic fellow.
I pulled a couple of the plugs which looked fine but there was oil on the plug wire holders which may be the source of a leak. I'll look around for good solutions on this.
Spark Plug Change...oil in plug wells. | Subaru Forester Owners Forum
I figured I was probably overdue on an oil change. My 2002 Forester has around 230K miles. I bought the Mobil 1 10-30 and the Fram Tough Guard filter. Draining the old oil 4 quarts at most came out. Also thinking of adding Lucas Oil Treatment.
I had that several times; it gets expensive so if you can do a diy solution that holds you are ahead of the game. If the bearing has damaged the hub then the problem can just re-emerge, and I ended up getting the whole knuckles at the junkyard for installation.
I checked with a mechanic today after my brother said the unburned gas smell was noticeable like the 60s cars. He said the plugs should be checked may have been fouled by the 10 or less mpg I was getting.
After replacing the coil, the car started running normally again.
The fuel injector cleaner was to get a cleaner burn, hopefully do something to help the catalytic converter. There are dedicated products for the cat converter, doubt they do a lot of good.
Looks like NGK is the OE on the coil, around $130 online. All the franchise auto stores sell a coil knock off for around $100, probably not much better than the China imports on ebay for $25 delivered.
- 1
I liked the way the mechanic loosened and pulled the plug wires while running for confirmation which I had not thought of.
What damage does running a Subaru with a bad coil, do? I ordered some fuel injector cleaner.
I'll look for a used Bosch unit at the junkyard, not worth taking the chance of a breakdown on the road.
With other cars other problems, as one friend said: Compression check? Dirty injectors, bad coil, spark plug, fuel pump/filter, pvc valve, egr valve...
Thanks for the recommendations; the last ignition coil was replaced on last October 15, so I went to the mechanic he emailed proof of the receipt/transaction and they reluctantly backed up their guarantee. Problem solved.
FYI the diagnostic on it was to remove coil wires while vehicle is running, two had no spark.
- 1
I replaced the ignition coil nearly a year ago and I was thinking of that too. The previous owner said that he had replaced his a year before. But when mine failed power loss was greater and the unit broke down physically. I replaced the cat converter last winter. I'm assuming running the car with gas not burning even for 50 miles puts an undo load on the cat converter.
I had two jobs I contracted for today. They involved driving down from New Canaan, CT to New Rochelle, NY. On the way to NY the Subaru lost power. I noticed a gas smell out of the exhaust previously. It bogs down when you put your foot on the gas pedal. Gas is burning excessively, 10 mpg at best. I ran a computer check on it and it showed cylinder #3 and #4 misfire. Also codes for O2 and evaporative came up. I disconnected the O2 censor into the main engine thinking that might effect improvement which it didn't.
My older brother warned about doing work with a car with problems such as towing a work unit if the car breaks down being very costly. I was able to get the work done without car breakdown. Is this likely electrical?
I've bought and sold a lot of precious metals and numismatic coins over the years; get weekly reports from numismatic crimes on thefts in the mail, houses, smash and grabs from cars and at coin shows. They almost never catch the thieves or retrieve the loot. One of the government officials' wife got cleaned out a few years ago and they pushed a very onerous law to document everything that comes in to pawn and coin shops, didn't do much good.
In CT, they are pushing a bill to make it illegal to sell a Cat that his not connected to a vehicle: https://www.usnews.com/news/best-states/connecticut/articles/2022-05-02/connecticut-bill-attempts-to-stop-catalytic-convert-thefts#:~:text=In general%2C the bill prohibits,converters they sell or transfer.
Not sure why they didn't just qualify that to aftermarket cats that are not worth that much.
Sounds very complicated. I have had cruise control on some of the Outbacks I have owned, it worked on the last one but not on my 2002 Forester. Not a priority for me as it is only useful when all the other cars are going at steady speeds on long trips which I don't do much.
2002 Subaru Forester wheel bearing replacement
Posted · Edited by ThosL
Ok, I'll pull the tire off and see what I'm dealing with. Typically Subaru upgraded with beefier parts such as brakes and easier to fix parts, the hub.
I found this video on the job on a 1998, probably much closer to the job and a lot more difficult:
