Dirthead
Everything posted by Dirthead
Frankenmotor troubleshooting 99 Legacy gt
Dirthead replied to Dirthead's topic in Subaru Retrofitting
WoodsWagon, Nice work that was it. Reset the timing belts and verified that I had the correct marks from (Legacy777 EJ22 timing)- (subaru_manual_scans). Thank you so much for your help, its been an amazing experience finishing this project. I don't know if this setup has been done before, but we now have a 99 Legacy GT running off a FrankenMotor. -
Need a little help. I have a 99 legacy that I have built a Franken motor for. The motor is installed and everything is connected. I attempted to start it and it will turn over but will not start/idle ... nothing. This is what I have. Motor: 96 ej25 block - phase I 94 - 95 ej22 sohc heads - phase I 99 legacy ECU Intake: ej22 Injectors: ej25 usdm Timing: All ej22 timing belt, idler pulleys, tensioner. Wiring: All EJ25 with the exception of the ignition plug Ignition: EJ22 MAF: EJ25 w/ ej25 sensors When I attempt to start I am getting spark and fuel. Any ideas would be greatly appreciated. The previous motor ran (2.5 dohc phase I) up until I removed it. The previous motor was pull because of a thrown main bearing.
Ok so a little update. wow took forever to find a metric feeler gauge. Started checking the tolerance on the valves only to find that what I was sent from the shop that I purchased the replacement ej25d from has sent me a with shimless buckets: "DOHC (1996) - SAE - 155 hp (116 kW) @ 5600 rpm 140 ft·lbf (190 N·m) at 2800 rpm" So my questions are: 1. Are there other specifications that I can look at to verify that this is the motor that I received? 2. What would it take to convert the above mentioned to a?: "DOHC (1997–1999) - SAE - 165 hp (123 kW) @ 5600 rpm 162 ft·lbf (220 N·m) at 4000 rpm" 3. I still have a complete 94,95 ej22s w/ egr could I put the ej22 heads on the phase I ej25 block and end up with a little more low end and use as a daily driver this way? If so what head gaskets would I use "11044AA610 gaskets" or something else? As I understand everything else will match up with the exception that I will use ej22 timing parts and intake.
I see what you mean to get the feeler gauge with out the SAE measurements on it. These are a little hard to find locally and all the places that I went to said that I could just use the sae based gauge and that being off three to four hundred thousandths would be that big of a deal. But some of these folks just didn't understand so I am waiting till I get the correct gauge to do it correctly.
Very nice, excellent post thank you so much for posting that. Thats a huge boost of confidence, I knew there was a way. I do have a few questions just a thought as I have been tearing down the engine: Could I use the jdm fuel injectors on my usdm intake and fuel rails? Any thoughts on drilling the hole for the egr? It looks like it is pretty much already there I just need to finish drilling and then tapping. How about the drill Millings? What is the best way of cleaning these so I don't contaminate the lower exhaust valves and egr pipe?
Again thank you all for being so responsive. A little update. So I picked up a jdm engine fresh from Japan. One of the last ones shipped prior to the tsunami. I started tearing into it today and pulled the head picked up the suggested factory "11044AA610 gaskets" wow these look sweet and much more durable then the OEM ones I just pulled out. However, I think I have a problem. While I was pulling the left head four buckets fell, three from the exhaust and one from the intake. I have read a few boards indicating that this is bad because I may end up with valve issues now if I put it back together and just guess at the order. Likewise to this I read that I can just check the valve clearances, chart, and put it back together based on proper specification / order. Do I understand this correctly? As I was tearing down the heads I did get a chance to spin the cams (On the JDM) and I now know what butter is like.
Ok did the spin check on the cams and they feel a little sticky especially when they are pushing the valves. I interpreted butter as the free spinning of something similar as the timing belt tensioner. Haven't got to the bearings yet. As for the lobes they are nice a shiny. Scoring to me would look like a really heavy wear or maybe scratches. The lobes look polished and from the contras of where the lobe makes contact with the bucket compared to the unworn portion of the lobe, it just looks polished. It feels like to me the left head cams spin more freely than the right head cams. (right head handling the damaged piston bearing) Gaskets originally mentioned in the follow (Thank you WJM BTW) would you still recommend these as a replacement on the JDM motor? Could you recommend a brand? Local market has felpro OEM's which I thought I had read that when replacing the hg's it is recommended to switch to either a new gasket supplied by Subaru, Bech Arnley, or Fel-Pro.. Thoughts?
While this is an option. I have pulled the 25 apart that came out of the car to find that the it has spun a bearing on one of the inner rods. I was told that there is some concern that the heads may now be contaminated with metal shavings from the spun bearing. While this is an excellent suggestion if I were to address the concerns with the potential contaminated heads this may prove feasible, however my next concern would be comparing the heads with 60,000 miles on them from the JDM motor vs. the heads from the inoperable motor with 180,000 +. What are your thoughts on this situation?
Thank all for the excellent input again. Now I know a little more about what I have and the options. What I have decided to do was get a JDM Motor. From what I have read I will need to swap intakes, fuel rails, and drill the EGR. My question is will I need to do the hg's on it or am I good with the JDM OEM hg's? I just ordered the motor today and should be here next week. So close I can taste it.
WJM - As you indicated following quote, would I still use the "11044AA610 gaskets" indicated for a EJ25D block swap to EJ251 block? Thank you BTW - if you would like I can set you up with the contact info of the guy looking to sell the EJ255 just PM me.
Numbchux - ey man i did a little more research on this and local market has a (Subaru Legacy 2000-2004 2.5L SOHC) (Point of reference) Wiki: http://en.wikipedia.org/wiki/Subaru_EJ_engine Power ISO: 123 kW (165 hp) @ 5600 RPM 226 N·m (167 ft·lbf) @ 4000 rpm Usage: Impreza 2.5RS, 2.5TS 99-04 (US) Impreza Outback Sport 02-04 (US) Forester 99-04 (US) Legacy 00-04 (US) Outback 00-04 (US) Baja 03-05 (US) Is this the 251 that you speak from this post: " " Do you know how I could verify that the motor is the 251? If this is do you know the logistics of swapping the block in and using all my 25D components such as heads, intake, egr? I am thinking that it should all swap over. Do you know what HG's I should install? Would there be a drop in compression?
Wow thank you all so much for the great amount of input on this. You have all really gone above and beyond in providing the answers needed to make a sensible decision. The story is this. I have been watching the local market for the last year and a half to find a replacement motor for the vehicle. In the last four weeks I have watched the motor in question (EJ255) go from 2000$ to 1300$. Apparently either no one has a need for it or there is something wrong with it. As I watched the price drop I started searching boards to determine if this would be both a mechanically feasible and logical swap. I am glad that I decided to post rather than just throwing money away. Considering that this 1300$ deal was only for this weekend and I know now that I am not missing out on anything. Moving on..... The next option that I have available is an EJ22 sohc I believe this was from a 94 or 95 impreza. I have read that this as well has been done provided the following configuration: Use the throttle body from my 25 Use the intake that is on the 22 New fuel rails and injectors Block needs to be drilled and tapped for the second starter bolt Exhaust will match because they are both dual ported Few items that I am unclear on is: Can I use my 25 ecu to run the 22 motor? As I understand the crank angle sensor on the 22 will not work with the expected knock sensor for the 25 therefore I would have to figure out a custom wiring solution to solve cel errors.
I have a 99 legacy limited outback with an EJ25D (I believe it is phase I). As the story goes blown HG's. My question is I have found a 2006 Subaru WRX EJ25 and I believe this to be a "US Market Impreza WRX STi MY04~MY07 (300 hp, 293 hp (New SAE standard))" - EJ257. I have all the parts from my EJ25D I have read here (http://www.ultimatesubaru.org/forum/showthread.php?t=112584) that it is possible to swap my heads on to the EJ257 short block and the intake and basically be back up and running. Will this work? Am I short siting other things that I will need to do to get it to work such as wiring? My goal is just to get the car back up and running pass emissions and inspection to make this a daily driver. I do not need additional power and I am not trying to Frankenstein. Any help with these questions would be greatly appreciated. Thank you, Dirt
