beatupsubaru
Everything posted by beatupsubaru
  1. Im looking to switch my abs/ cruise control fuse on my car because one, I dont like abs, two my abs sensor is broken so i can't use it, and three I drive long distances and like my cruise control. I have tried fuse taps the slip over the blade of the fuse and I cant get them to fit into the slot on the fuse box. I even went as far as to pull the fuse box out of the car to try to make them fix. I had this successfully wired by forcing two wires into the fuse slot but since the fuse box is right next to my clutch petal they kept getting pulled out. Do they make a false fuse that has two taps on the top? Any ideas thanks
  2. I am in the market for a 5 steelies and im looking to get a set of offroad tires that i can use on the street if i have to and a set of street tires that will hold me to the ground in slick conditions. I have a 1998 OBW and im thinking about lifting it about 6 in. any suggestions?
  3. the cable for the hood release broke when i put a new fender on. I managed to hit a telephone pole so the hod was bent up before it fly up and i planned to modify it anyway. If you have a pic of your hood could you send it to me rks@belizebridsltd.com
  4. im in wilmington delaware. the hood for ym car is a 97-99 green with scoop. I was planning on riveting diamond plate steel on the hood to cover up the dents I was going to leave the center part still green because its not dented. I have yet to find a local junk yard i can deal with. ill check the abs rings as soon as i get a lift. does anyone have a picture of what im looking for?
  5. I found the abs fuse last night. We did brakes and rotors as well as alxes that ngiht so i have no idea where to start in fixing this problem. the latest problem is the hood ripped up last night while i was driving I have it tied down currently but its even more dented then it was before. does anyone have any idea what a hood goes for?
  6. I have found out the my great mechanic friend has managed to put the wrong axles. Now my abs now doesnt work and prevents me from braking safely. Is there a fuse i can pull to disable the abs I have a 1998 legacy outback 5 speed with a 2.5
  7. I also seems to have lost all dash lights and have no response from the dimmer on the turn signal lever. Is this a fuse problem or did i break something
  8. I just put new axles rotors and pads on the front end of my 1998 subaru legacy outback 2.5 stick. I have an abs light that comes on every once and awhile. along with that I have a sharp return in the brake petal about 80% of the time I am braking it pulsates sharply with a slight grinding noise. I'd love to know what this is so i can fix it cause i am lost. please help me
  9. Telephone poles and I have been meeting alot more frequently then I would like and it seems that all of these impacts could of been stopped by a good brush guard. I cant seem to find one anyone have any ideas on where to look? 1998 Legacy outback
