location of ECU?
lionel025 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did that but all I found was the ABS ECU:confused:
location of ECU?
Hi. I own a 1991 legacy FWD 5 speed. Where is the ECU on my car? I just cant seem to find it. Im going to a pick and pull and figured I'd grab an extra.
water temp sensor engine code
lionel025 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXK thanks. And yes the one to the ECU was 5V. But I dont see the info you were talking about on page 62.
lionel025 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell one of them is giving me 5 volts but the other is giving me 10volts
lionel025 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes anyone know the voltage that should be going to the temperature sensors?
92 Legacy Automatic Creaking Popping Noise Turning
lionel025 replied to LSS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlmost a guaranteed half shaft replacement. They usually cost around $70 and its a pretty quick job. Maybe 1-2 hours.
car died on hiway won't restart
lionel025 replied to Tahoe Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnever use harbor freight:eek:
lionel025 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll the wires look good (no corrosion noticeable) but im not sure how the voltage is, thats why im asking for what the voltage should be going to them. I got the sensor from NAPA and I installed it. I work on cars all the time, but im new to Subarus.
lionel025 replied to lionel025's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe green test connectors are definitely not connected right now. Any other ideas?
Hi everyone. I purchased a 1991 legacy 2.2L fwd about 4 months ago. When I first got it everything was perfect. Two days later though the check engine light came on when I turned on the car. Then the code eventually went off (soft code). But then it came back and never left. I tried to run a MODIS on it to find the issue but it wouldnt make a connection. Then I brought it to Pep Boys (a bad decision I know) and after 2 hours of them struggling with it they told me it was the oxygen sensor. I replaced and tried to clear the code but it was still there. After doing research I found out that if you plug the two wires under the dash together then it blinks in a code to tell you whats wrong. It is giving me two long blinks and one short one which I found out to be the water temperature sensor. I replaced both sensors, coolant, and the thermostat yet I still cant get rid of the code. Also the radiator fans are always on starting immediately when you put the car in the start position. Is there another temperature sensor I am missing? Please help because I haven't smogged the car and the DMV won't give me another extension. I no longer have a form of transportation. Thanks!
lionel025
