ondarvr
Everything posted by ondarvr
  1. Yes, please supply the info needed to order one, whether from you or your supplier. I need at least one right now.
  2. It will down shift if you push the peddle down, it's works normally once it shifts that first time.
  3. Thanks, but no flashing light. I did try one thing though, I let the car warm up for about 10 minutes prior to driving it and and it shifted almost normally. I was told there is a thermal delay sensor that can malfunction and possibly cause a problem going into second gear. I need it to cool back down completely and then I'll drive it again cold and see what happens.
  4. I've lurked here for a few years and found most of the answers to my questions by searching the forum, but on this one I couldn't find the answer. My daughter has a 98 Legacy OB with 220,000 miles on it (new head gasket and all that goes with it at 190,000), in the last few weeks it started not wanting to shift up from 1st to 2nd when its cold. After the first up shift it will work fine the rest of the day unless it sits all day when she's at work, then that first up shift will be an issue again. It will shift solidly from neutral to either Reverse or Drive with no hesitation or slipping, it's only that first up shift that is a problem. Before I take it in I wanted to try a few things, so I drained the 3-4 quarts of fluid from the pan and rellied, no change, then drained some out and added Trans X. The result is it shifts great after that first up shift, but it still takes about a 1/4 mile for it to make that first shift, so far no real change. The fluid looked great before this and had been change a little over a year ago. Thanks for reading this.
  5. I don't live far away and will watch for it.
