Everything posted by HILLBILLYHARLOT
hill holder
I have said HH, and it seems to leak right under the rotation. I'm going to disconnect the cable and hope that remedies the leak, I'm sick of buying brake fluid, it feels weird on my hands and I hate the smell... Anywho, if that doesn't work, I'm going to RELUCTANTLY get my hands back into the brake fluid and put a "T" in place of the bastage... I HATE BRAKE FLUID!!!!
SERIOUS mystery wiring issue...
I found a few links at a boneyard, and so far, that's remedied the issue, even made the gauge volt meter read correctly. I have another black, and green and red, just in case something blows again. Now, on the the HEATER ISSUE... Fawk it's cold in that car! Since one heater hose is hot, the other warm... I'm betting it's a plugged core and I will be trying to clean it out tomorrow. Thanks for all the help guys, I called subaru, and they couldn't even tell me what link I needed....
MUD!!!! Well, I NEVER take my precious off road.... That car has seen some SERIOUS abuse from me, I am very impressed! That's the only reason I'm still a subaru fan, dispite the majority of the market subaru's have.... I am NOT a fan of hippys, yuppies or liberals It has proven itself as a tough piece of iron!
I agree... The large white wire that goes into the fusible link box did get hot & is discolored, I tried to pull it out, I was going to cut it and re connect it, but it doesn't come out easy and I didn't want to break the box. Thanks for the info on the link, I'll see if I can find one close. And idea how many years of subarus had the same link there in case I find an older or newer one in a bone yard??
Ok, update.... The fusible link in question is the closest to the firewall and when the wire that was in place of said link burned up, I had NO power to windows, and not even a click when I tried to start it. I took the car to NAPA and had the battery tested in car, and found out that the volt meter in the dash isn't reading right, it's only charging @ 13v. So the alteranator is off the hook. I don't yet know why I ran it for 40 miles and the lights & heater ran the batt dead but the car still ran. If anyone knows what that link should be so I can order one, I'll start there, then try to figure out why the accessories drained a good battery.. One more thing, I used the red link when it first burned up, and I was able to run it that way for a bit. I need to know the amps or size or whatever it is of that fusible link.... Nobody in part stores knows fawkall about subarus and it's pizzin me off!!!!
I have a test light, and a continuity tester. I checked all the wires and they all look good. I got a brand new battery because NAPA guy said it could be bad. I knew it wasn't the issue but I gladly took his new battery considering I ran mine dead Anyone know what to look for as far as replacing the original fusible link for the starter?? Mine was replaced with a random piece of wire last spring, so I don't know what it was originally.... 86 GL 1800...
I haven't checked the wires from the Alt, or starter yet, but I'll start there. When the link first blew, it melted and smelled horrible! I patched a hole in Alt wire this summer, maybe it's not enough... Hmm... Thanks guys I'll go check those..
It started with the fusible link for the starter blowing. So, I replaced it. Next time I tried to start it.... nothing again. So, I made one with an inline fuse. I started at 7.5, and everytime I tried to start it, it blew fuses up to a 30 amp... I noticed it was sitting at 16v at an idle, then when I accelerate, it went up to 18. Last night, I was trying to get it home, and in 40 miles drained a brand new battery. Alternator tested @ 14.5 at the local NAPA, four times this morning. I have a short somewhere obviously, I just don't know where to start. It used to have starting issues where I'd have to wiggle the neg & pos cables, but it hasn't had that since I cleaned the cables at the battery and put new terminal connectors on. I'm not a wiring magician, I don't know how to read a volt meter, but I can learn HELP!!!!
WCCS 12 Site and Location are Set
I assure you, it has
AAAAAAAAAAAAAND I will be there....in my fabulous 1986 wagon...the "boozearoo" will be nice to meet some people:grin:
Northwest-WA BBQ Meet N Greet Cancelled. :(
Crap!!! Well, if there is enough people that want to come out to Evans Creek for a meet and greet and wheeling, I wouldn't mind organizing a shindig... Let me know, how about Aug 13th and 14th? I'm planning a trip with a bunch of friends anyway, and will be up there, and since you have a job (high five) and can't have your BBQ....any takers????????
I'm going to try and make it
When do Loyale wheel Bearings go?
:eek:
hard to push clutch
:eek: ok!!!! will do
EA82 won't idle :o
OK, I just rebuilt my Hitachi on my EA82. It's really not bad. I took everything out and cleaned it, one thing at a time. Take 1 jet out at a time, clean it, spray carb cleaner through the holes, and when you replace the accelerator pump, DONT forget to put the little ball bearing (check valve) in!!!! I also replaced the O rings on the venturis, (sounds scary but really not) and I took out what I think was the idle solenoid, it was full of corrosion, cleaned, let dry and put back in carb. It runs like a whole new car! I also shortened my throttle return spring, it wasn't tight enough and would idle up when I took my foot off the throttle, or pushed in the clutch. I'd be happy to walk you through a rebuild, I think it will fix your issues...Oh, I also had a bad base gasket...
I have about 266,000 miles on my car, howling like a werewolf....not sure they've ever been replaced. I'm going to try the front's first...I can feel them it's so bad...seems like I can feel the vibration and resistance in the floor even!!! I can't wait to see what they look like..should be awesomely terrible!!! HA!!! I'll have to post up pics:lol:
hard to push clutch
Mine is on the steering shaft....has been all along i guess because it's worn down the splines on the shaft.... Does that mean someone has replaced the cable at some point? Since it works fine, should I bother to move it?
87 GL wagon, few questions...
I have an 86 GL, EA82 with a 5spd.......Had the same idle issue, as well as a few others. I put a rebuild kit in the carb, and shortened the throttle return spring a bit, and it's all better now. You might want to put some wd40 or something up the cable, it helped my clutch cable a lot...Now on to wheel bearings.....
ea82 valve tick
Mine has a valve tick when cold, and this morning it started to knock. anyone have a guesstimate as to how long I have till I throw a rod??!! I don't want to put money into the car now that I found this knock, it's an 86 GL with an EA82, carbourated....and a total pain in my arse....oh, and *highjack*
New chick...
The BOOZE-A-ROO LIVES!!!! Rebuilt the carb, and now she's good!!!
86 gl with "mystery" carb?
You guys kick rump roast...Jerry, I'll call you in a bit...I have a 425 number so you know who's calling:banana:
New chick...
Smooth operators are the best...
I specifically remember looking at the kit, and reading those numbers!!!! I'm glad I came here!!! Thanks!!! And the guys at my local NAPA have been great till now, but then again, I always get parts for my pickup and it's a chevy easy to find stuff for!!!
New chick...
Thanks everyone, this is my 1st suby, I'm learning as I go, I know they have long life engines and I hope I can get mine going well enough to make it worth it!!! car has 260,000 miles on it, engine is a replacement I'm sure, it needs work but it's fun to stump-jump....when it runs
New chick...
HA!! trust me, will take a lot more than that to freak me out!!! LOL!!! I have a pic of me changin my tire on my PHOTOBUCKET. I'm trying to put up a profile pic, I got an avi, but i dont see where to post profile pic...Im a RATARD sorry..
