Tom63050
Posts posted by Tom63050
I'm looking to install better seats than the stock ones. At 5'11" I find the stock seats don't go back far enough on my 84 wagon, so my butt does all the support work rather than spreading the load over the lower thighs. Tiring on longer trips.
Two questions:
Can I just relocate the stock frame rails farther back somehow to get the stock seats to go back farther?
If not, what are better seats to install? Either using the stock EA81 frame rails or maybe an easy mod. I don't have welding skills or access to a person who does.
Thanks.
Thanks for the input! I'll get an EA82 radiator when the time comes.
I have an 84 GL wagon, D/R 4 speed. Wanna buy a new radiator and would like to get a two-row if possible. Radiators.com only lists an OEM replacement type, and for a 1.6 liter motor. How do I get hold of a two-row for my EA81?
Did EA81 Turbos come with two-row rads? What year(s) were the turbos?
Also, on the radiators.com website I noticed that there are different prices for EA81 radiators depending on body style. I would think the Brats, sedans, wagons and hatches would all have the same radiator since the sheetmetal would be basically the same.
I change fuel filters on carbed cars every 10-15K miles, and keep a spare in the car along with tools to change it. Has saved my a$$ a number of times over the years.
My experience with gutting the cat on an EA82 carbed car was that it lost torque due to too little restriction. Suggest you drill a hole thru the cat's guts with a hole saw, rather than take it all out.
Most people run the stock 195 degree thermostat but you can get 180, which might be useful if you live where it's hot or you tow/carry heavy loads. You should probably stay with 195 for the better heat.
For air bubbles: take off the rdiator cap, start the motor, turn the heater all the way to hot--I don't think you need to turn the fan on. This will circulate coolant thru the heater core. Bubbles will pop as they get to the hole where the radiator cap is, due to low ambient air pressure, compared to the pressure inside the cooling system. Add coolant if necessary to keep it full, so no more air bubbles occur. When it starts to rise at the hole where the radiator cap goes, due to the coolant heating up, put the cap back on. By then there should be no bubbles in the system.
Probably a broken timing belt on the driver's side. That controls the distributor too.
Meeky,
Some possibilities:
1. broken fuse.
2. broken resistor coils. Don't know if the EA81s had these like the EA82s, which have them behind the glove box.
3. broken blower motor. Check if juice gets to motor. If so, then a junkyard blower is called for. Try Sunny's in Culpeper; they have several EA81s.
Tom in Centreville
Thiis is probably the single best mod for the SPFI EA82s. Basically, you take out the airbox and cut a hole or drill a bunch of small holes in the bottom of the airbox.
Tom
At http://www.webercarburetors.com under accessories you can find a snorkel for our 32/36s.
Hi Paul,
No it's not sold yet, thanx 4 axing. Thought I had a nibble but am getting no reply to my voicemail messages. Oh well.... But the financial need is no longer there. Looking forward to playing with it in the snow down here; hope it snows A LOT, like a huge one (22"!!!) we had last year, over the President's Day holiday. I was stuck on duty (security guard) for 38 HOURS! Mega paycheck for that week, almost $1000 after taxes.
Tom
Try these:
............................Primary.......Secondary
Fuel......................140.............140
Idle........................60..............55
Air Correction.........165.............160
These are certainly in the ballpark. Emulsion tubes are probably OK. What jets do you have now, and what kind of car did the carb come off of?
Tom
The adaptor for the EA82 OHC motor's intake manifold is different from the adaptor for the EA81 pushrod motor's manifold. You can put the EA82 manifold on the EA81, but it would be easier to just go buy the EA81 manifold.
For an engine to trans adaptor plate, try Kennedy Engineered Products. That's their specialty.
I did the airbox mod, and then installed a free-flowing Turbo muffler. Definitely cutting out the bottol of the airbox is the single best mod you can make--it's free and easy, and gives noticeable improvement over 4000 RPM. Maybe 10 horses. The muffler made no difference, but that may be because I did the airbox first. Possibly doing the muffler first would have made a noticeable difference, but I believe the big restriction is in the intake.
And pulling off the PS and AC sounds good, too. My Loyale wagon has a non-functioning AC switch, so I've been thinking of pitching the AC. Might as well do the PS too...
The 2.2 is OHC, therefore wider than the OHV 1.8 motor. I think it won't fit between the frame rails, without either altering the frame rails or installing a high lift kit, like 7" or so, to put the heads under the frame rails.
Better seats for 84 wagon
Posted
So...how do you relocate the seats on the rails? Or would it be really obvious by just looking at them?
