Roger Stokes
Everything posted by Roger Stokes
  1. I have a 2001 forester and the check engine light was on went to auto zone and had it scaned and needed the 02 sensor front one so I replace it. Then 2 months later check engine came on again, had it checked and it ran a coed P0420 with 3 different causes,1 Rich A/F ratio, 2 Ignition system malifuction, 3 Faulty catalytic converter. Any advice on which on and what to do? Thanks, Roger
  2. I`m changeing out all the wheel bearing in my 2001 forester. I noticed the cv boots on the inner front are split so as I`m inspecting them I noticed a slit play in and out of the outer cv joint not any play in twisting it back and forth though. Is this standard to have a slit play in and out? They were changed about 40,000 miles ago. Thanks, Roger
  3. Thanks Mike, yes I would like to talk to you about it on the phone. And give me a good time to cal. Thanks, Roger
  4. ok, thanks I`m useing the subaru brand bearing and seals(haven`t ordered yet) I thought the bearing was one peice, you say it has an inner and an outer race? and is there 2 seals on the inner and 1 on the outer? And I`ve read where you need to use the threaded bolt style bearing/race/seal kit to slowly push in and out, but you use the driver style kit? where you tap with a hammer? next I`m need to do the front, how is it different? Thanks so much for your help!
  5. Hello, I`m about to change out the wheel bearing in the rear on my 2001 forester. Does any one know where I can rent a wheel bearing puller kit? Or does anyone have one I can rent or buy? Thanks, Roger
  6. I have a 2001 forester with 97,000 miles on it. How do you know when the wheel bearings are bad, because it`s making some road noise? Thanks, Roger
  7. I looked and forgot to connect the fuel swich, it`s all good now!, Thanks
  8. I`ve replaced my 01 forester engine with one from LKQ, so I know they tested it, but now that I`ve put it in, it won`t start up or even hit. I know I had at least half a tank of gas in it, ( it set up for 2 months befor I put the engine in) But now the gas gage is showing empty with the light on. Is there a fuel pump reset button/fuse or something? Please help? Thanks, Roger
  9. Yes, I haven`t gotten a answer to this question. Does anyone know the torque ft. lbs on the 2001forester flywheel manual?...the crankshaft bolts and the bolts on the back of the flywheel that holds that thin plate to the flywheel. Thanks, Roger
  10. Does anyone know the torque ft. lbs on the 2001forester flywheel manual?...the crankshaft bolts and the bolts on the back of the flywheel that holds that thin plate to the flywheel. Thanks, Roger
  11. The bolts on the back of the flywheel 2001 forester that bolts the plate to the flywheel, what type of socket fits it?, it a strange head.
  12. Yeah, I should have the bolt ring turned about 1/16, because theres only 1/16 clearence between the bolts and the clutch springs. So as the clutch wears it could get into the bolts. So that 1/16 less in thickness than a new one flywheel wont interfer with the clutch padle or anyother operation? Thanks
  13. I had my flywheel turned (2001 forester manual) and I compaired the thickness of mine to a new one, and mine must have been turned befor cause now theres about 1/16 of and inch less than a new one. Will this effect the operation of the clutch, clutch arm, throw out bearing, etc? Do I need to go with the new one? Thanks, Roger
  14. Does anyone know the torque lbs on the 2001 forester manual flywheel bolts?
  15. I`m replaceing clutch and p p, on my 2001 forester. I had the flywheel turned and they must have taken to much off, cause now there`s only about 1/16 of an inch between the flywheel bolts and the clutch springs....so I think I`ll just have that inner disk that the bolts go though turned down 1/16 of an inch so I`ll have 1/8 of an inch clearence.....now I know why Subaru doesn`t recoment turning the flywheel. So turning that inner disk 1/16 of an inch wont hurt will it? It`s about 5/8 thick it seems. And what is the ft. lbs on the bolts for the flywheel tourked to? Thanks, Roger
  16. Hello, What brand Oil,and oil filter and antifreeze coolent(I have the additive from Subaru) are as good as Subaru brand? And also the spark plugs? I have a 2001 forester. Thanks, Roger
  17. Ok thanks, I have a mechnic thats gonna do it for me. But he`s never done a subaru befor.
  18. Hey I have a chilton manual fpr Legacy/Forester 2000-06 and I`m having the headgaskets and timing belt and all the seals replaced on my 2001 forester. Is it acurrent and true? Thanks, Roger
  19. Update I sent pictures to the company I bought engine from and they are paying for the labor and parts for head gasket. Great! Thanks
  20. I`m replaceing all the seals befor I put the engine back in the car. I understand there is a O ring with the seal on the oil pump shaft. Can the O ring be replaced from the from the seal side? or does the shaft have to be pulled from the inside, oil pan? If so is it nessary to replace? I`m haveing my Nissan mec. change everything out for me I`m just getting all the information befor I order all the parts. It`s a 2001 forester Thanks, Roger
  21. I`m replaceing all the seals befor I put the engine back in the car. I understand there is a O ring with the seal on the oil pump shaft. Can the O ring be replaced from the from the seal side? or does the shaft have to be pulled from the inside, oil pan? If so is it nessary to replace? I`m haveing my Nissan mec. change everything out for me I`m just getting all the information befor I order all the parts. It`s a 2001 forester. Thanks, Roger
