Everything posted by maarten
rear wheel brake sylinder and wheel bearing
I have the three part singel bearing. and it do not fit my car. two different ways to mount wheel bearings. My rear wheel setup is more like front wheel setup. where you push the bearing from both sides with a sleeve between. I use two two single tapered roller bearing with a spacer at the rear, in front I use two ball bearing with a spacer. I can not find any number on the bearing, brake sylinder. Problem one, no dealer in norway have it. Problem two. rockauto have thee diffrent 11/16, 5/8 and 3/4.
I have a 1984 1800 4WD subaru BRAT, MV I need a rear wheel brake sylinder and do not know what to order. rockauto has tree different sylinders. I have two single tapered roller bearing with a spacer between. Not the wheel bearing rockauto has. can someone please tell me what I need, part numbers, and where to get it attach file wheel bearing
headgasket
maarten replied to maarten's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgot head off.. it seems to be a bigger problem to get it on, without distroying the new headgasket. time will tell.
headgasket
maarten replied to maarten's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave done that. When I pull out the bolt it as far as I can, it is inside the block by 0.5 to 1.0 cm regards maarten
headgasket
maarten replied to maarten's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfirst my back is bad; problem. one bolt is 0.5 to 1 cm to long to clear engine block. inner lower bolt maarten
headgasket
have to renew head gasket on the left side of my legacy 1.8 year 1991 is there a way to take of the head without removing the engine? regards maarten
