Posts posted by maarten
I have the three part singel bearing. and it do not fit my car. two different ways to mount wheel bearings. My rear wheel setup is more like front wheel setup. where you push the bearing from both sides with a sleeve between. I use two two single tapered roller bearing with a spacer at the rear, in front I use two ball bearing with a spacer. I can not find any number on the bearing,
brake sylinder. Problem one, no dealer in norway have it. Problem two. rockauto have thee diffrent 11/16, 5/8 and 3/4.
I have a 1984 1800 4WD subaru BRAT, MV
I need a rear wheel brake sylinder and do not know what to order. rockauto has tree different sylinders.
I have two single tapered roller bearing with a spacer between. Not the wheel bearing rockauto has.
can someone please tell me what I need, part numbers, and where to get it
attach file wheel bearing
- 1
got head off.. it seems to be a bigger problem to get it on, without distroying the new headgasket. time will tell.
pull the bolt out as far as it will go, then slide the head out the same way. then lift both up.
the bolt is too long to clear the head, but not too long to clear the block.
have done that. When I pull out the bolt it as far as I can, it is inside the block by 0.5 to 1.0 cm
regards
maarten
first my back is bad;
problem. one bolt is 0.5 to 1 cm to long to clear engine block. inner lower bolt
maarten
have to renew head gasket on the left side of my legacy 1.8 year 1991
is there a way to take of the head without removing the engine?
regards
maarten
rear wheel brake sylinder and wheel bearing
Posted
my rear wheel bearing setup looks somthing like this
